Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
SHIFTphone8 Display Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
95
All Time:
550
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
If you prefer a video guide: link to YouTube
Is the repair really necessary? (possibly just a screen protector, or a different defect)
Note on the SHIFT shop (tools and replacement parts). In the future also available in the iFixit shop.
Repairing or opening your SHIFTphone does not void the warranty. However, you must bear the costs that arise during or as a result of the repair yourself.
Important: If any step is unusually difficult or something does not want to release, please contact SHIFT before further damage occurs. They will provide you with direct support.
      • Disconnect
      • Power off
      • Remove the bumper
      Ask FixBot
      • Insert a tool into the notch on the back cover
      • Pry off the back cover
      • Insert a tool into the notch on the replacement battery
      • Pry up the replacement battery, then pull it downwards to remove it
      Ask FixBot
      • 8 screws under the back cover
      • 2 screws next to the USB port
      • white seals
      • All screws are the same size
      Ask FixBot
      • Work your way up from the bottom using a fingernail or opening pick.
      • Only release the display; leave it on the device.
      Ask FixBot
      • Now you can carefully lift the display with a slight upward movement to avoid straining the cable.
      • Make sure that the ribbon cable underneath is never under tension.
      • Rotate the display along the short bottom edge. Carefully place the display face down on the SHIFT6mq.
      • If you want to be safe, you can place a piece of film, paper, or an anti-static cloth between the display and the now open phone.
      Ask FixBot
      • Release the display connector from the short side by prying in the direction of the adjacent connector.
      • Once the display is released, you can carefully set it aside.
      Ask FixBot
      • Open connector
      • Release glued fingerprint reader from its housing
      • Unplug glued cable
      • Unplug cable
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Author
with
SHIFTPHONES
1,362 Reputation
7 Guides authored
SHIFT Member of SHIFT
Community
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 95
All Time: 550
