SHIFT6mq Sub-Board Replacement
    1. SHIFT6mq Sub-Board Replacement, Preparation: step 1, image 1 of 3 SHIFT6mq Sub-Board Replacement, Preparation: step 1, image 2 of 3 SHIFT6mq Sub-Board Replacement, Preparation: step 1, image 3 of 3
      • Turn off your SHIFT6mq.
      • Remove the bumper.
      • Use your fingernail (pick/spatula) to detach the back cover at the gap between the frame and the back cover on the bottom left corner (when looking at the back of the phone).
      • Place your finger in the notch, centered under the battery, and lift it out.
      Ask FixBot
    2. SHIFT6mq Sub-Board Replacement, Removing the screws: step 2, image 1 of 1
      • Use the T3 screwdriver to loosen all 14 screws. Work your way along the ascending numbering of the screws. This is how you make sure you don't forget any.
      • The rubberized hole in the top center is for the microphone and not a screw.
      • If there is a white seal on the screw, you can easily pierce it with the screwdriver. The positions may vary.
      • All screws in the SHIFT6mq are identical (M1.4 x 3.5). So you can keep them all together in one place.
      Ask FixBot
    3. SHIFT6mq Sub-Board Replacement, Remove the Display: step 3, image 1 of 2 SHIFT6mq Sub-Board Replacement, Remove the Display: step 3, image 2 of 2
      • Now run your fingernail between the display frame and the middle frame of the SHIFT6mq.
      • If you don't want to do it with your fingernail, you can of course use a pick or spatula.
      • Very gently peel the display along all sides of the phone.
      • The display is still connected to the device! Never pull it off forcefully or more than a few millimeters.
      • If the display is detached from the frame all around, you can go to the next step...
      Ask FixBot
      • Now you can carefully lift off the display, with a slight upward movement to avoid straining the cable.
      • Make sure that there is never any tension on the ribbon cable underneath.
      • Rotate the display around the short, bottom edge. Carefully place the display glass-side down on the SHIFT6mq.
      • If you want to be on the safe side, you can place a sheet of plastic, paper, or an antistatic cloth between the display and the now open phone.
      Ask FixBot
      • Detach the display connector from the short side with a lever movement in the direction of the adjacent connector.
      • Be careful not to damage or accidentally pry off any of the adjacent SMD components.
      • Once the display is detached, you can carefully put it aside
      Ask FixBot
      • Due to a subsequent improvement, there are two different versions of the sub board. In the newer version, a screw has been added.
      • Loosen the screw that sits above the USB socket.
      • If the circuit board is held on with a second screw, loosen that one too
      Ask FixBot
      • Insert the pointed end of the spatula into the screw hole closest to the USB socket and lift the circuit board slightly.
      • Now lift the board slightly on the other side, at the corner of the phone, that will loosen it from its tight seat.
      • Gently push the whole circuit board towards the center of the device towards its short side. But only until the circuit board has come loose from the holder on the outside of the device.
      • The sub board is still connected with two ribbon cables. Please do not rip it too hard out of the device.
      Ask FixBot
      • Carefully fold the circuit board upwards in the direction of the lines.
      • Disconnect the ribbon cable's compression connector by prying it off to the side.
      • To detach the antenna cable's small coaxial connector, slide a pry tool or tweezers under the cable close to the connector and then lift vertically away from the circuit board.
      • Now the sub board is free and you can place it to the side.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
SHIFTPHONES
1,362 Reputation
7 Guides authored
SHIFT Member of SHIFT
Community
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 57
All Time: 837
