This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
SHIFT6mq Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
51
All Time:
498
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
You can purchase a replacement screen for your SHIFTPHONE in the official SHIFTPHONE shop.
You will need a Torx T3 screwdriver and your fingernail as a tool. Optionally, you can use an opening pick, a spudger, and tweezers.
You can find the required Torx T3 screwdriver in the original packaging of your SHIFTPHONE. Otherwise, you can of course also purchase one separately.
The repair takes approximately 15 minutes, and the workspace should be clean and clear.
Repairing your SHIFTPHONE does not void your warranty. However, you will be responsible for any costs incurred if damage occurs due to an incorrect repair.
Important: If any step is unusually difficult or something does not want to release, please contact SHIFT here before any major damage occurs. You will receive direct support there.
Parts
Tools
      • Note: Turn off your SHIFT6mq first and remove the bumper, as well as the back cover.
      • To remove the back cover, loosen the back cover with your fingernail (or an opening pick) at the gap between the frame and the back cover at the bottom left corner (when looking at the back of the phone).
      • Now remove the replacement battery by lifting it out at the gap on the bottom right.
      • Then place the phone on a soft, dust-free, and lint-free surface (e.g., a microfiber cloth).
      • - Image 1: Removing the bumper; Image 2: Showing the back cover slot; Image 3: Back cover opened by a finger (from the side); Image 4: Removing the replacement battery (split image: finger in the recess by the replacement battery & replacement battery lifted)
      Ask FixBot
      • Note: For this step, you will now need the Torx T3 screwdriver.
      • Now, remove all identical 14 screws from the frame. (See markings in the image)
      • Make sure you remove all the screws. Some screws have a white coating, some marked with an S. You can push the screwdriver through this coating and unscrew the screw as usual.
      • All screws in the SHIFTPHONE are identical (length, head, etc.). Therefore, it is not important to remember where you removed them from. You can simply keep them all together in one place. For this, for example, the original box is recommended.
      • Image 1: All screws marked with red circles on the back of the phone
      Ask FixBot
      • Now you will need the hard fingernail or an opening pick.
      • Insert the fingernail/opening pick between the display frame and the midframe of the SHIFT6mq.
      • Start at the bottom right corner (viewing the display), continue the movement to the bottom left corner, then to the top left corner, and finally the top right corner.
      • The display should now be released from the frame. But be careful: The display is still connected to the motherboard!
      • Image 1: Opening the frame with an opening pick; Image 2: Marking the sequence for opening; Image 3: Display lying on the inner frame
      Ask FixBot
      • Now, release the display connector from the short side by using a prying motion toward the adjacent connector.
      • CAUTION Do not release the connector from the ribbon cable side or the long side. Doing so can cause damage to the connector.
      • Once the connector is released, you can place the display next to the phone.
      • Image 1: Releasing the connector; Image 2: Display lying on a mat next to the phone
      Ask FixBot
      • Before installing the new display, you need to transfer the earpiece speaker from the old display to the new one.
      • Here too, it is recommended to use tweezers to release the earpiece speaker from its housing—otherwise, the earpiece speaker may be damaged.
      • Place the earpiece speaker into the designated housing in the new display in the same position and orientation, and press it down gently.
      • Image 1: Prying out the earpiece speaker; Image 2: Transferring the earpiece speaker
      Ask FixBot
      • Now comes the most delicate step!
      • Place the display on the phone with the back facing up.
      • Position the display connector over the socket on the motherboard and ensure that both parts are perfectly aligned. The display connector must not be tilted, otherwise contact pins can break!
      • When both connectors are properly aligned, gently press down on the display connector with a finger until you can feel and hear it snap into place.
      • Image 1: Display lying on the phone; Image 2: Display connector on the socket (detail); Image 3: Finger pressing the connector down
      Ask FixBot
      • After the display connector is connected, place the display on the phone so that the screen is facing outward.
      • Then, press the display along the bezel onto the midframe.
      • Image 1: Display lying correctly on the frame; Image 2: Display connected to the frame (same perspective > showing gap closed)
      Ask FixBot
      • Now turn your SHIFT6mq over and screw all 14 screws back into the designated holes.
      • Make sure that the screws are tightened, but not so tight that they damage the threads!
      • Image 1: All screw holes marked and all screws reinserted.
      Ask FixBot
      • Once all screws are replaced, insert the replacement battery, attach the back cover, and pull the bumper over the phone.
      • Recommended: Protect your screen with additional tempered glass. This is included with the replacement screen. A video tutorial on how to apply the tempered glass can be found here: applying tempered glass
      • We hope the repair was successful and you can enjoy using your phone again.
      • Image 1: Three-part: 1) Battery at an angle during insertion 2) Back cover on and 3) Bumper wrapped around; Image 2: Tempered glass applied
      Ask FixBot
Congratulations! You made it through. Enjoy using your repaired SHIFT6mq!
Jakob
191 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 51
All Time: 498
