SHIFT6mq Disassembly
  1. SHIFT6mq Disassembly, Preparation: step 1, image 1 of 3 SHIFT6mq Disassembly, Preparation: step 1, image 2 of 3 SHIFT6mq Disassembly, Preparation: step 1, image 3 of 3
    • Turn off your SHIFT6mq.
    • Remove the bumper.
    • Use your fingernail (pick/spatula) to detach the back cover at the gap between the frame and the back cover on the bottom left corner (when looking at the back of the phone).
    • Place your finger in the notch, centered under the battery, and lift it out.
    Ask FixBot
  2. SHIFT6mq Disassembly, Removing the screws: step 2, image 1 of 1
    • Use the T3 screwdriver to loosen all 14 screws. Work your way along the ascending numbering of the screws. This is how you make sure you don't forget any.
    • The rubberized hole in the top center is for the microphone and not a screw.
    • If there is a white seal on the screw, you can easily pierce it with the screwdriver. The positions may vary.
    • All screws in the SHIFT6mq are identical (M1.4 x 3.5). So you can keep them all together in one place.
    Ask FixBot
  3. SHIFT6mq Disassembly, Remove the Display: step 3, image 1 of 2 SHIFT6mq Disassembly, Remove the Display: step 3, image 2 of 2
    • Now run your fingernail between the display frame and the middle frame of the SHIFT6mq.
    • If you don't want to do it with your fingernail, you can of course use a pick or spatula.
    • Very gently peel the display along all sides of the phone.
    • The display is still connected to the device! Never pull it off forcefully or more than a few millimeters.
    • If the display is detached from the frame all around, you can go to the next step...
    Ask FixBot
    • Now you can carefully lift off the display, with a slight upward movement to avoid straining the cable.
    • Make sure that there is never any tension on the ribbon cable underneath.
    • Rotate the display around the short, bottom edge. Carefully place the display glass-side down on the SHIFT6mq.
    • If you want to be on the safe side, you can place a sheet of plastic, paper, or an antistatic cloth between the display and the now open phone.
    Ask FixBot
Finish Line
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
SHIFTPHONES
1,335 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,569
