SGIN X15S Back Panel Replacement
    1. SGIN X15S Back Panel Replacement, Back Panel: step 1, image 1 of 3 SGIN X15S Back Panel Replacement, Back Panel: step 1, image 2 of 3 SGIN X15S Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Remove the eight top and middle 7.3 mm screws using the Phillips #0 screwdriver.
      • Remove the six bottom and side 4.4 mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    2. SGIN X15S Back Panel Replacement: step 2, image 1 of 3 SGIN X15S Back Panel Replacement: step 2, image 2 of 3 SGIN X15S Back Panel Replacement: step 2, image 3 of 3
      • Use the nylon spudger to gently pry a bit of the back panel open. With the opening pick, go all the way around until the back panel is loose.
      • Pull the back panel off the laptop.
      Ask FixBot
JadenS
673 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 63
All Time: 515
