SEGA Genesis Flashback Controller Back Cover Replacement
  1. SEGA Genesis Flashback Controller Back Cover Replacement, Controller Back Cover: step 1, image 1 of 3 SEGA Genesis Flashback Controller Back Cover Replacement, Controller Back Cover: step 1, image 2 of 3 SEGA Genesis Flashback Controller Back Cover Replacement, Controller Back Cover: step 1, image 3 of 3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
2 other people completed this guide.
Omar Shorab
261 Reputation
2 Guides authored
Cal Poly, Team S24-G12, Maness Spring 2018 Member of Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 470
