Ryobi RY40109 20" Mower Blade Replacement
    1. Ryobi RY40109 20" Mower Blade Replacement, Blade: step 1, image 1 of 3 Ryobi RY40109 20" Mower Blade Replacement, Blade: step 1, image 2 of 3 Ryobi RY40109 20" Mower Blade Replacement, Blade: step 1, image 3 of 3
      • Before working with the blade, remove the battery.
      • Firmly grasp the battery, depressing the battery release and slide the battery out.
      Ask FixBot
    2. Ryobi RY40109 20" Mower Blade Replacement: step 2, image 1 of 1
      • Turn the mower upside down on a flat, stable surface.
      Ask FixBot
    3. Ryobi RY40109 20" Mower Blade Replacement: step 3, image 1 of 2 Ryobi RY40109 20" Mower Blade Replacement: step 3, image 2 of 2
      • Preventing the blade from spinning is an important safety step!
      • Use an 8" to 10" block of 2x4 to prevent the blade from spinning counterclockwise.
      • You may have to experiment a bit to position it correctly.
      Ask FixBot
    4. Ryobi RY40109 20" Mower Blade Replacement: step 4, image 1 of 1
      • Protect your hands by putting on your heavy-duty canvas gloves while working around the blade.
      • Using a 15 mm socket wrench, remove the blade nut by turning it counterclockwise.
      Ask FixBot
    5. Ryobi RY40109 20" Mower Blade Replacement: step 5, image 1 of 3 Ryobi RY40109 20" Mower Blade Replacement: step 5, image 2 of 3 Ryobi RY40109 20" Mower Blade Replacement: step 5, image 3 of 3
      • Remove the nut spacer and blade insulator.
      • Remove the blade.
      Ask FixBot
    6. Ryobi RY40109 20" Mower Blade Replacement: step 6, image 1 of 3 Ryobi RY40109 20" Mower Blade Replacement: step 6, image 2 of 3 Ryobi RY40109 20" Mower Blade Replacement: step 6, image 3 of 3
      • Identify the alignment shapes on the blade hub.
      • Install the new blade on the hub using the alignment posts.
      Ask FixBot
    7. Ryobi RY40109 20" Mower Blade Replacement: step 7, image 1 of 3 Ryobi RY40109 20" Mower Blade Replacement: step 7, image 2 of 3 Ryobi RY40109 20" Mower Blade Replacement: step 7, image 3 of 3
      • Replace the insulator, spacer, and nut.
      Ask FixBot
    8. Ryobi RY40109 20" Mower Blade Replacement: step 8, image 1 of 1
      • Re-block the blade to keep it from spinning clockwise this time.
      Ask FixBot
      • Set the torque wrench to between 310-360 in.lbs.
      Ask FixBot
    9. Ryobi RY40109 20" Mower Blade Replacement: step 10, image 1 of 1
      • Tighten the blade nut with the torque wrench by rotating the wrench clockwise.
      • You have completed the replacement! Time to mow the grass!
      Ask FixBot
Finish Line
Jim Keplinger
181 Reputation
1 Guide authored
CSU Sacramento, Team 1-8, Laflen Fall 2024 Member of CSU Sacramento, Team 1-8, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G8
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 41
Past 30 Days: 236
All Time: 1,772
