Ryobi P411 Casing Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
52
All Time:
318
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to open up the casing on your Ryobi P411. The casing is the outside of the sander that protects the essential parts that make the sander function properly. It is easily distinguished since the plastic casing is a lime green and grey color. In order to replace any part of the Ryobi P411, use this replacement guide first. Make sure to remove the battery before you begin.
Tools
    1. Ryobi P411 Casing Replacement, Pad Assembly: step 1, image 1 of 3 Ryobi P411 Casing Replacement, Pad Assembly: step 1, image 2 of 3 Ryobi P411 Casing Replacement, Pad Assembly: step 1, image 3 of 3
      • Remove the sanding pad to expose the screws at the bottom of the sander.
      Ask FixBot
    2. Ryobi P411 Casing Replacement: step 2, image 1 of 3 Ryobi P411 Casing Replacement: step 2, image 2 of 3 Ryobi P411 Casing Replacement: step 2, image 3 of 3
      • Remove the four M5 x 8.9mm screws with a T6 Torx screwdriver.
      • Remove the pad assembly.
      Ask FixBot
    1. Ryobi P411 Casing Replacement, Casing: step 3, image 1 of 2 Ryobi P411 Casing Replacement, Casing: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the eight M4 x 18.5mm screws from the side of the casing.
      Ask FixBot
    2. Ryobi P411 Casing Replacement: step 4, image 1 of 3 Ryobi P411 Casing Replacement: step 4, image 2 of 3 Ryobi P411 Casing Replacement: step 4, image 3 of 3
      • Open the sander by separating each half of the case apart.
      Ask FixBot
Paula Meier
769 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 52
All Time: 318
