Ryobi P202 Right Side Case Replacement
    1. Ryobi P202 Right Side Case Replacement, Battery: step 1, image 1 of 3 Ryobi P202 Right Side Case Replacement, Battery: step 1, image 2 of 3 Ryobi P202 Right Side Case Replacement, Battery: step 1, image 3 of 3
      • The battery can shock you. Only touch plastic, non-conductive components.
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      Ask FixBot
    1. Ryobi P202 Right Side Case Replacement, Right Side Case: step 2, image 1 of 2 Ryobi P202 Right Side Case Replacement, Right Side Case: step 2, image 2 of 2
      • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
      Ask FixBot
    2. Ryobi P202 Right Side Case Replacement: step 3, image 1 of 2 Ryobi P202 Right Side Case Replacement: step 3, image 2 of 2
      • Gently lift the casing from the drill body.
      • Take the casing completely off the drill body to gain access to the interior of the drill.
      • The Ryobi P202 casing has Part #: 200690001
      Ask FixBot
Joseph Eckstein
1,596 Reputation
9 Guides authored
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 80
All Time: 1,243
