Ryobi P202 Level Gauge Replacement
  1. Ryobi P202 Level Gauge Replacement, Battery: step 1, image 1 of 3 Ryobi P202 Level Gauge Replacement, Battery: step 1, image 2 of 3 Ryobi P202 Level Gauge Replacement, Battery: step 1, image 3 of 3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Level Gauge Replacement, Right Side Case: step 2, image 1 of 2 Ryobi P202 Level Gauge Replacement, Right Side Case: step 2, image 2 of 2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Level Gauge Replacement: step 3, image 1 of 2 Ryobi P202 Level Gauge Replacement: step 3, image 2 of 2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Level Gauge Replacement, Level Gauge: step 4, image 1 of 3 Ryobi P202 Level Gauge Replacement, Level Gauge: step 4, image 2 of 3 Ryobi P202 Level Gauge Replacement, Level Gauge: step 4, image 3 of 3
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
Joseph Eckstein
1,596 Reputation
9 Guides authored
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 14
All Time: 458
