Ryobi Evercharge P714TH Filter Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
22
Past 30 Days:
103
All Time:
623
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 6 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
A common reason the Ryobi Evercharge P714TH loses suction is a clogged filter.
This model is designed for easy filter maintenance—no tools are required. Regular cleaning keeps the vacuum performing at its best and extends its lifespan. You can also follow this guide to replace the filter, as it walks you through accessing it.
Replace the paper filter every 3–6 months, depending on use. Wash the mesh filter (screen assembly) as needed, and make sure it is completely dry before reassembly. Avoid using solvents on plastic parts, as they can damage the plastic.
Before you begin, make sure the vacuum is powered off and the battery is removed.
    1. Ryobi Evercharge P714TH Filter Replacement, Filter: step 1, image 1 of 2 Ryobi Evercharge P714TH Filter Replacement, Filter: step 1, image 2 of 2
      • Push the gray slider forward to unlock the locking tabs.
      • Remove the dust bin from the vacuum.
      Ask FixBot
    2. Ryobi Evercharge P714TH Filter Replacement: step 2, image 1 of 2 Ryobi Evercharge P714TH Filter Replacement: step 2, image 2 of 2
      • Press the black tabs on the sides of the paper filter to release and remove it.
      Ask FixBot
    3. Ryobi Evercharge P714TH Filter Replacement: step 3, image 1 of 2 Ryobi Evercharge P714TH Filter Replacement: step 3, image 2 of 2
      • Reach into the dustbin and pull out the mesh filter.
      • The mesh filter is the one you can clean.
      • Do not clean the paper filter. That filter cannot be cleaned and needs to be replaced every 3-6 months.
      Ask FixBot
    4. Ryobi Evercharge P714TH Filter Replacement: step 4, image 1 of 2 Ryobi Evercharge P714TH Filter Replacement: step 4, image 2 of 2
      • Tap the dust out of the mesh filter into the waste basket.
      • Use a cloth to wipe out any additional dirt and dust from the filter.
      • For a deep clean, rinse the filter with cold or lukewarm water. Do not use hot water as this may damage the filter. Wait 24 hours until the filter is completely dry before putting it back in the vacuum.
      • Reassembling the vacuum with the mesh filter still wet may damage it.
      Ask FixBot
To reassemble the vaccuum, follow these instructions in reverse order.
Make sure the plastic nozzle is completely sealed or the vacuum will not power on.
Christopher Wilson
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 103
All Time: 623
