Shop the Holiday Gift Guide
Rubik's Cube Spring Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
40
Past 30 Days:
179
All Time:
485
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your 3×3 Rubik's Cube feels too loose, too tight, or turns unevenly, use this guide to replace or adjust the internal spring located beneath the center cap and screw.
The spring is part of the cube's tensioning system. It works with the center screw to control how tightly the pieces are held together, which affects the cube's stability, corner-cutting ability, and overall turning performance. A worn, damaged, or incorrectly tensioned spring can cause the cube to feel unstable, pop pieces out during solves, or become difficult to turn.
Before replacing the spring, check that loose screws, dirt inside the mechanism, or insufficient lubrication do not cause the issue. If the spring is damaged or has lost its tension, replacing it can restore the cube's performance.
Tools
    1. Rubik's Cube Spring Replacement, Spring: step 1, image 1 of 1
      • Inspect the cube to see which side needs to be fixed by turning each face.
      Ask FixBot
    2. Rubik's Cube Spring Replacement: step 2, image 1 of 1
      • Once you've indicated which side needs fixing, remove the center cap from the cube.
      Ask FixBot
    3. Rubik's Cube Spring Replacement: step 3, image 1 of 3 Rubik's Cube Spring Replacement: step 3, image 2 of 3 Rubik's Cube Spring Replacement: step 3, image 3 of 3
      • Grab a screwdriver and remove the screw at the center of the cube.
      • Be careful when unscrewing the middle as the pieces of the top layer can come apart.
      Ask FixBot
    4. Rubik's Cube Spring Replacement: step 4, image 1 of 3 Rubik's Cube Spring Replacement: step 4, image 2 of 3 Rubik's Cube Spring Replacement: step 4, image 3 of 3
      • Take off the screw and spring from the center. Be careful not to lose the screw and spring.
      • Take off the spring and replace it with a new one.
      Ask FixBot
Author
with
Jensen Thankachan
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 179
All Time: 485
