Rosewill NEON M62 Sensor Cover Replacement
    1. Rosewill NEON M62 Sensor Cover Replacement, Bottom Panel: step 1, image 1 of 1
      • Place the mouse so the bottom is facing upwards.
      • Remove the plastic skates.
      • These are not shown in the picture since they were missing from the device.
      • Remove the two 5 mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    2. Rosewill NEON M62 Sensor Cover Replacement: step 2, image 1 of 1
      • Use the opening tool along the side of the mouse to open up it.
      • This may take multiple attempts to do so; be patient and careful not to break the mouse.
      Ask FixBot
    3. Rosewill NEON M62 Sensor Cover Replacement: step 3, image 1 of 2 Rosewill NEON M62 Sensor Cover Replacement: step 3, image 2 of 2
      • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
      Ask FixBot
    1. Rosewill NEON M62 Sensor Cover Replacement, Sensor Cover: step 4, image 1 of 1
      • Remove the four 5 mm screws with a Philips #00 screwdriver.
      Ask FixBot
    2. Rosewill NEON M62 Sensor Cover Replacement: step 5, image 1 of 2 Rosewill NEON M62 Sensor Cover Replacement: step 5, image 2 of 2
      • Remove the center clear plastic piece, known as the sensor cover.
      Ask FixBot
Sean Turk
217 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 56
All Time: 355
