Shop the Holiday Gift Guide
Roof Shingle Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
148
All Time:
2,499
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A broken asphalt roof shingle will be repaired through this guide. Roof shingles, especially asphalt ones, wear and tear after years of sun damage, rain, and heavy wind. They need to be replaced because water can get under the broken shingle and cause the wood to rot or create a leak in the roof. The guide will be specific to repairing one tab of the shingle sections.
Tools
    1. Roof Shingle Replacement, Roof shingle: step 1, image 1 of 1
      • Remove the broken shingle by lifting the nails with the claw side of a hammer.
      • Use caution when handling a hammer and nails.
      Ask FixBot
    2. Roof Shingle Replacement: step 2, image 1 of 1
      • Remove the single broken shingle, carefully, without ripping out the shingles above.
      Ask FixBot
    3. Roof Shingle Replacement: step 3, image 1 of 1
      • Remove the adhesion strip off of the new shingle.
      Ask FixBot
    4. Roof Shingle Replacement: step 4, image 1 of 1
      • Slip the new shingle in place, and line it up where the old shingle previously was.
      Ask FixBot
    5. Roof Shingle Replacement: step 5, image 1 of 2 Roof Shingle Replacement: step 5, image 2 of 2
      • Secure the shingle with three 7/8" roofing nails.
      • Be careful when hammering in the nails.
      Ask FixBot
    6. Roof Shingle Replacement: step 6, image 1 of 1
      • Slightly lift the edges of the shingle and apply a thin layer of cement along it.
      Ask FixBot
    7. Roof Shingle Replacement: step 7, image 1 of 1
      • Press down the edges to lock the shingle in place.
      Ask FixBot
Author
with
Marie Albrecht
169 Reputation
1 Guide authored
2 Guide Comments
Great post! Roof repair is something you should only really do as a quick patch though. If one of your shingles has fallen off, odds are a lot more of them are going to be falling off soon too. You need to find the Best Quality shingles just to make sure that they stay on as long as your other ones.
Best Quality - Reply Share
Yeah those 3 in 1s are definitely NOT good quality, they are old and soon to be extinct. (Good riddance)
OOtysweat97 - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 148
All Time: 2,499
