Roku XD 2050X Remote IR LED Replacement
  1. Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: step 1, image 1 of 2 Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: step 1, image 2 of 2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote IR LED Replacement: step 2, image 1 of 2 Roku XD 2050X Remote IR LED Replacement: step 2, image 2 of 2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote IR LED Replacement: step 3, image 1 of 1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote IR LED Replacement: step 4, image 1 of 1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote IR LED Replacement: step 5, image 1 of 1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote IR LED Replacement, Remote IR LED: step 6, image 1 of 1
    • Desolder the two contacts for the IR LED.
    • Remove the IR LED from the circuit board.
    • For help with soldering view the ifixit soldering guide.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 18
All Time: 884
