Roku XD 2050X Power Port Replacement
  1. Roku XD 2050X Power Port Replacement, Case: step 1, image 1 of 3 Roku XD 2050X Power Port Replacement, Case: step 1, image 2 of 3 Roku XD 2050X Power Port Replacement, Case: step 1, image 3 of 3
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Power Port Replacement: step 2, image 1 of 2 Roku XD 2050X Power Port Replacement: step 2, image 2 of 2
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Power Port Replacement: step 3, image 1 of 3 Roku XD 2050X Power Port Replacement: step 3, image 2 of 3 Roku XD 2050X Power Port Replacement: step 3, image 3 of 3
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Power Port Replacement: step 4, image 1 of 2 Roku XD 2050X Power Port Replacement: step 4, image 2 of 2
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Power Port Replacement: step 5, image 1 of 1
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Power Port Replacement, Power Port: step 6, image 1 of 1
    • Desolder the 3 contact points.
    • Remove the power port from the motherboard.
    • For help with soldering view the iFixit soldering guide.
2 Comments
Where do you buy power port ?
John - Reply
For Roku 2 XS
John - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,101
