Roku 4 Remote Control Motherboard Replacement
  1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: step 1, image 1 of 1
    • Place the remote control facing down on the table, so that the buttons are facing downwards.
  2. Roku 4 Remote Control Motherboard Replacement: step 2, image 1 of 2 Roku 4 Remote Control Motherboard Replacement: step 2, image 2 of 2
    • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
  3. Roku 4 Remote Control Motherboard Replacement: step 3, image 1 of 2 Roku 4 Remote Control Motherboard Replacement: step 3, image 2 of 2
    • Remove the batteries from the battery compartment.
  4. Roku 4 Remote Control Motherboard Replacement: step 4, image 1 of 1
    • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
  5. Roku 4 Remote Control Motherboard Replacement: step 5, image 1 of 1
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
    • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
  6. Roku 4 Remote Control Motherboard Replacement: step 6, image 1 of 3 Roku 4 Remote Control Motherboard Replacement: step 6, image 2 of 3 Roku 4 Remote Control Motherboard Replacement: step 6, image 3 of 3
    • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
Hank Harrison
449 Reputation
3 Guides authored
Baylor, Team S5-G4, Williams Spring 2017 Member of Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,590
