Roku 2 Motherboard Replacement
    1. Roku 2 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
      • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
      Ask FixBot
    2. Roku 2 Motherboard Replacement: step 2, image 1 of 1
      • Gently use the plastic opening tool to pry the rubber pads off.
      Ask FixBot
    3. Roku 2 Motherboard Replacement: step 3, image 1 of 1
      • Remove the four Phillips #000 screws from the bottom of the case.
      Ask FixBot
    4. Roku 2 Motherboard Replacement: step 4, image 1 of 1
      • Gently remove the under side of the device.
      Ask FixBot
    5. Roku 2 Motherboard Replacement: step 5, image 1 of 1
      • Remove the middle component that is held in place by the top and bottom of the device.
      Ask FixBot
    6. Roku 2 Motherboard Replacement: step 6, image 1 of 1
      • Remove the cover over the A/V ports on the front of the device.
      Ask FixBot
    7. Roku 2 Motherboard Replacement: step 7, image 1 of 1
      • Remove the board from the plastic enclosure.
      Ask FixBot
Eric Rawls
378 Reputation
2 Guides authored
USF Tampa, Team 1-5, Sullivan Fall 2015 Member of USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 95
All Time: 1,573
