Rogers XB6 Modem Deep Clean
    1. Rogers XB6 Modem Deep Clean, Remove Top and Bottom of Shroud: step 1, image 1 of 3 Rogers XB6 Modem Deep Clean, Remove Top and Bottom of Shroud: step 1, image 2 of 3 Rogers XB6 Modem Deep Clean, Remove Top and Bottom of Shroud: step 1, image 3 of 3
      • First start off by removing the four rubber feet from the bottom. Then using a plastic prying tool, wedge open the bottom between the plastic shroud and the metal bottom casing.
      • Using the prying tools again, work on removing the top plastic cover of the shroud.
      • The goal is to pry open the clips that are holding the plastic assembly in place.
      • ⚠️Be careful when lifting with your prying tool, it is easy to accidentally wedge open only the transparent plastic cover, which is glued to the opaque bottom.
      Ask FixBot
    2. Rogers XB6 Modem Deep Clean, Remove Screws from Top: step 2, image 1 of 1
      • Next, we need to remove the three T2 (or T3, sorry I can't remember) screws that were sitting under the top cover of the modem.
      • ⚠️This will void your warranty. ⚠️
      • I didn't take a photo but, the bottom screw was covered with a warranty seal that requires to be broken.
      • ℹ️ Take note that the top rectangular structure above the three screws is the cooling fan for the modem.
      Ask FixBot
    3. Rogers XB6 Modem Deep Clean, Remove the Bottom Two Screws and Remove Outer Casing: step 3, image 1 of 3 Rogers XB6 Modem Deep Clean, Remove the Bottom Two Screws and Remove Outer Casing: step 3, image 2 of 3 Rogers XB6 Modem Deep Clean, Remove the Bottom Two Screws and Remove Outer Casing: step 3, image 3 of 3
      • Start by removing the bottom two screws circled in red.
      • Next, while gently prying open the two tabs (in orange), push down from the top of the modem, so that it can slide away from the external casing.
      • ℹ️Take note that the inputs and outputs of the modem are physically attached to the internal components and are not attached to the external housing.
      Ask FixBot
    4. Rogers XB6 Modem Deep Clean: step 4, image 1 of 2 Rogers XB6 Modem Deep Clean: step 4, image 2 of 2
      • The modem is now ready for cleaning, I recommend reading through other electronic cleaning guides to get a general sense of what to do.
      Ask FixBot
    5. Rogers XB6 Modem Deep Clean, SD Card Location: step 5, image 1 of 3 Rogers XB6 Modem Deep Clean, SD Card Location: step 5, image 2 of 3 Rogers XB6 Modem Deep Clean, SD Card Location: step 5, image 3 of 3
      • I didn't personally poke around with anything internally, I thought it was curious that there was an SD card and slot here. I'll let others speculate what it is for though.
      Ask FixBot
Larry David
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 74
All Time: 212
