This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
The fabric is glued onto a plastic panel. Unfortunately, this panel is glued onto the underlying component.
Carefully pry off the fabric panel all the way around using a narrow screwdriver. Depending on the amount of glue used, this may be easier or harder.
Unfortunately, a few pins will break off in the process. However, this should not affect the stability. It is possible, however, that the sound quality may suffer.
Remove the 7 screws.
The pins broke off during removal.
Lithium-ion replacement battery, CLICL18500, 3.7 V, 1400 mAh
The replacement battery must be desoldered to be replaced.
I also noticed that a microphone is built-in. When the Rockbox is connected to a phone, you can also answer calls. It then functions as a speakerphone.
Follow these steps in reverse order to reassemble your device.
