Roborock S5 Battery Replacement
    1. Roborock S5 Battery Replacement, Battery: step 1, image 1 of 3 Roborock S5 Battery Replacement, Battery: step 1, image 2 of 3 Roborock S5 Battery Replacement, Battery: step 1, image 3 of 3
      • Power down your Roborock S5 vacuum.
      • Place it on a flat work surface with the wheels facing up.
      • Use a Phillips #2 screwdriver to remove the seven 14 mm screws holding the bottom cover in place.
      • Use the Phillips #2 screwdriver to loosen one captive screw holding the side brush in place.
      • Remove the side brush and set it aside for now.
      • Gently remove the bottom panel.
      Ask FixBot
    2. Roborock S5 Battery Replacement: step 2, image 1 of 1
      • Lift the battery out by the two tabs on top and set it beside the robot vacuum.
      • The battery will still be attached to the robot vacuum at this point.
      Ask FixBot
    3. Roborock S5 Battery Replacement: step 3, image 1 of 3 Roborock S5 Battery Replacement: step 3, image 2 of 3 Roborock S5 Battery Replacement: step 3, image 3 of 3
      • Disconnect the battery from the robot vacuum by squeezing and pulling the plug connector from the board.
      Ask FixBot
12 other people completed this guide.
0 Guide Comments
Past 24 Hours: 29
Past 7 Days: 184
Past 30 Days: 649
All Time: 11,943
