Roborock Q5 LiDar Sensor Replacement
    1. Roborock Q5 LiDar Sensor Replacement, Side Brush: step 1, image 1 of 1
      • Power off your Roborock and place the device on a flat surface with the wheels facing up.
      • Position the robot so the five-pronged side brush is on the bottom right side.
      Ask FixBot
    2. Roborock Q5 LiDar Sensor Replacement: step 2, image 1 of 2 Roborock Q5 LiDar Sensor Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to loosen the single captive side brush screw.
      • The screw is attached to the side brush so they cannot be separated.
      Ask FixBot
    3. Roborock Q5 LiDar Sensor Replacement: step 3, image 1 of 2 Roborock Q5 LiDar Sensor Replacement: step 3, image 2 of 2
      • Lift the side brush up and off.
      Ask FixBot
    1. Roborock Q5 LiDar Sensor Replacement, Battery: step 4, image 1 of 3 Roborock Q5 LiDar Sensor Replacement, Battery: step 4, image 2 of 3 Roborock Q5 LiDar Sensor Replacement, Battery: step 4, image 3 of 3
      • Use a Phillips screwdriver to remove the seven 15 mm screws from the bottom panel.
      Ask FixBot
    2. Roborock Q5 LiDar Sensor Replacement: step 5, image 1 of 3 Roborock Q5 LiDar Sensor Replacement: step 5, image 2 of 3 Roborock Q5 LiDar Sensor Replacement: step 5, image 3 of 3
      • Gently lift off the bottom panel cover.
      • If the bottom panel is stuck, use a plastic spudger along the edges to gently lift it out of place, then remove it by hand.
      Ask FixBot
    3. Roborock Q5 LiDar Sensor Replacement: step 6, image 1 of 3 Roborock Q5 LiDar Sensor Replacement: step 6, image 2 of 3 Roborock Q5 LiDar Sensor Replacement: step 6, image 3 of 3
      • Use the two white straps to lift the battery out slightly to reveal the battery connector.
      • The battery is still connected to the robot vacuum. Take care not to strain the battery cable.
      Ask FixBot
    4. Roborock Q5 LiDar Sensor Replacement: step 7, image 1 of 3 Roborock Q5 LiDar Sensor Replacement: step 7, image 2 of 3 Roborock Q5 LiDar Sensor Replacement: step 7, image 3 of 3
      • Using moderate pressure, squeeze and pull on the four-wire connector to disconnect the battery from the robot vacuum.
      Ask FixBot
    1. Roborock Q5 LiDar Sensor Replacement, LiDar Sensor: step 8, image 1 of 3 Roborock Q5 LiDar Sensor Replacement, LiDar Sensor: step 8, image 2 of 3 Roborock Q5 LiDar Sensor Replacement, LiDar Sensor: step 8, image 3 of 3
      • Remove the three 10 mm Phillips screws that secure the side brush motor.
      • Lift the side brush motor up and out of its housing.
      Ask FixBot
    2. Roborock Q5 LiDar Sensor Replacement: step 9, image 1 of 2 Roborock Q5 LiDar Sensor Replacement: step 9, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the eight 11 mm screws from the front sensor panel cover.
      Ask FixBot
    3. Roborock Q5 LiDar Sensor Replacement: step 10, image 1 of 2 Roborock Q5 LiDar Sensor Replacement: step 10, image 2 of 2
      • Gently lift and remove he thin black sensor housing bracket.
      • Pull the front sensor panel cover away from the robot.
      Ask FixBot
    4. Roborock Q5 LiDar Sensor Replacement: step 11, image 1 of 1
      • Use a Phillips screwdriver to remove one 14 mm Phillips screw from the battery housing.
      • Use a Phillips screwdriver to remove the eleven deep-set 14 mm Phillips screws from the bottom panel.
      Ask FixBot
    5. Roborock Q5 LiDar Sensor Replacement: step 12, image 1 of 2 Roborock Q5 LiDar Sensor Replacement: step 12, image 2 of 2
      • Carefully flip the device and set it down.
      • Pinch together the two dustbin tabs and pull up on the dustbin to remove it.
      Ask FixBot
    6. Roborock Q5 LiDar Sensor Replacement: step 13, image 1 of 2 Roborock Q5 LiDar Sensor Replacement: step 13, image 2 of 2
      • Use a Phillips #2 screwdriver to remove two 15 mm Phillips screws from the front panel cover.
      Ask FixBot
    7. Roborock Q5 LiDar Sensor Replacement: step 14, image 1 of 3 Roborock Q5 LiDar Sensor Replacement: step 14, image 2 of 3 Roborock Q5 LiDar Sensor Replacement: step 14, image 3 of 3
      • Gently lift and remove the top cover off of the robot vacuum.
      • If the top panel is stuck, use a plastic spudger along the edges to gently lift it out of place, then remove it by hand.
      Ask FixBot
    8. Roborock Q5 LiDar Sensor Replacement: step 15, image 1 of 3 Roborock Q5 LiDar Sensor Replacement: step 15, image 2 of 3 Roborock Q5 LiDar Sensor Replacement: step 15, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws from the LiDar sensor cover.
      • Gently lift off the sensor cover.
      Ask FixBot
    9. Roborock Q5 LiDar Sensor Replacement: step 16, image 1 of 3 Roborock Q5 LiDar Sensor Replacement: step 16, image 2 of 3 Roborock Q5 LiDar Sensor Replacement: step 16, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 9 mm screws that secure the LiDar sensor.
      • Lift the sensor from the vacuum.
      Ask FixBot
    10. Roborock Q5 LiDar Sensor Replacement: step 17, image 1 of 3 Roborock Q5 LiDar Sensor Replacement: step 17, image 2 of 3 Roborock Q5 LiDar Sensor Replacement: step 17, image 3 of 3
      • Grip and the white LiDar sensor cable connector and pull it directly out of its socket.
      • Remove the LiDar sensor.
      Ask FixBot
4 other people completed this guide.
Joyce T
319 Reputation
2 Guides authored
2 Guide Comments
The replacement lidar sensor is available on Ali Express. OEM model # is LDS04RR. Here's a link to the correct part (as of Sept 2025): Original Roborock LDS Replacement LDS04RR For Robot Vacuum Cleaner Q5 / Q7/ Q7 Max / S8 Series Accessories Laser Distance Sensor - AliExpress
Before replacing, take a good look at the motor shaft of the lidar sensor - it can get tangled with hair and lint and may be the reason your sensor is not spinning. Cleaning the shaft may save the need for a new part (but not the hassle of dissassembly)
Gullimukin - Reply Share
Past 24 Hours: 20
Past 7 Days: 152
Past 30 Days: 602
All Time: 7,893
