Roborock Dyad Pro Combo: Fan Unit
Views: 7.3K
View statistics:
Past 24 Hours:
11
Past 7 Days:
81
Past 30 Days:
476
All Time:
7,259
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a teardown guide for the suction fan unit of the Roborock Dyad Pro Combo 2in1 wet&dry handheld vacuum cleaner.
This is not a teardown for the whole of the Dyad Pro Combo and will focus solely on the fan unit.
Tools
    1. Roborock Dyad Pro Combo: Fan Unit, Removing the display: step 1, image 1 of 3 Roborock Dyad Pro Combo: Fan Unit, Removing the display: step 1, image 2 of 3 Roborock Dyad Pro Combo: Fan Unit, Removing the display: step 1, image 3 of 3
      • Start by grabbing the display and twisting it counter clockwise.
      • This may require a lot or a little bit of force. Eventually it will give and at that point you can lift it up.
      • Once removing the display, remove the cable connecting it.
      Ask FixBot
    2. Roborock Dyad Pro Combo: Fan Unit, Removing the motherboard: step 2, image 1 of 2 Roborock Dyad Pro Combo: Fan Unit, Removing the motherboard: step 2, image 2 of 2
      • Remove all the cables from the motherboard.
      • Then remove the 2 screws and take the motherboard out.
      • Use this as a reference during reassembly or take a better picture yourself.
      Ask FixBot
    3. Roborock Dyad Pro Combo: Fan Unit, Removing the battery: step 3, image 1 of 3 Roborock Dyad Pro Combo: Fan Unit, Removing the battery: step 3, image 2 of 3 Roborock Dyad Pro Combo: Fan Unit, Removing the battery: step 3, image 3 of 3
      • Remove the plastic housing.
      • Remove the battery. (It is not held in place by anything. Just pull it out.)
      Ask FixBot
    4. Roborock Dyad Pro Combo: Fan Unit, Handle pt.1: step 4, image 1 of 3 Roborock Dyad Pro Combo: Fan Unit, Handle pt.1: step 4, image 2 of 3 Roborock Dyad Pro Combo: Fan Unit, Handle pt.1: step 4, image 3 of 3
      • Remove the screw from the inside.
      • Use your hand to force a small gap between the handle and the housing.
      • Fit blunt-tipped tweezers or a small flat head screwdriver into the gap.
      Ask FixBot
    5. Roborock Dyad Pro Combo: Fan Unit, Handle pt.2: step 5, image 1 of 3 Roborock Dyad Pro Combo: Fan Unit, Handle pt.2: step 5, image 2 of 3 Roborock Dyad Pro Combo: Fan Unit, Handle pt.2: step 5, image 3 of 3
      • Push it upwards, until it won't re-seat by itself.
      • Push the cable as far into the handle as it will go to prevent damaging it once you get the handle apart.
      • If you do happen to pull a cable from the connector, the last image is a reference to how it's meant to be assembled. Try to reassemble it if you pull a cable out.
      Ask FixBot
    6. Roborock Dyad Pro Combo: Fan Unit, Handle pt.3: step 6, image 1 of 3 Roborock Dyad Pro Combo: Fan Unit, Handle pt.3: step 6, image 2 of 3 Roborock Dyad Pro Combo: Fan Unit, Handle pt.3: step 6, image 3 of 3
      • Remove the handle by defeating the latches using a Plastic card or iFixit's Jimmy.
      • Remove the screws, then remove the black plastic retainer.
      • Remove the grey lever by pulling it off. It is latched onto the main assembly.
      Ask FixBot
    7. Roborock Dyad Pro Combo: Fan Unit, Connector PCBA assembly pt.1: step 7, image 1 of 3 Roborock Dyad Pro Combo: Fan Unit, Connector PCBA assembly pt.1: step 7, image 2 of 3 Roborock Dyad Pro Combo: Fan Unit, Connector PCBA assembly pt.1: step 7, image 3 of 3
      • Back inside, remove the 2 screws by the bunch of cables.
      • Move to the outside and force a gap between the main housing and the electrical contacts housing.
      • Use a plastic card to get the rest of the latches to unlatch.
      Ask FixBot
    8. Roborock Dyad Pro Combo: Fan Unit, Connector PCBA assembly pt.2: step 8, image 1 of 2 Roborock Dyad Pro Combo: Fan Unit, Connector PCBA assembly pt.2: step 8, image 2 of 2
      • Remove the PCBA and the cable leading from the bottom.
      • Back inside, remove the 4 screws and the black foam on the bottom.
      Ask FixBot
    9. Roborock Dyad Pro Combo: Fan Unit, Finish!: step 9, image 1 of 2 Roborock Dyad Pro Combo: Fan Unit, Finish!: step 9, image 2 of 2
      • And finally, take it apart.
      Ask FixBot
Finish Line
DegenFixer
5,750 Reputation
24 Guides authored
2 Guide Comments
Thank you! Such a life saver.
Price Andrews - Reply Share
Great teardown! Too bad that in my case, the source of foul smells turned to be the motor, which doesn't look like it can be disassembled non-destructively due to the duct being glued shut. Major design flaw in which moisture and/or dirty water can leak directly into the motor housing.
Also, in my opinion the motor access screws should be located on the bottom of the case, not inside covered up by everything else, requiring full teardown just to clean the business end.
M T - Reply Share
Past 24 Hours: 11
Past 7 Days: 81
Past 30 Days: 476
All Time: 7,259
