Ring Video Doorbell 3 Camera Replacement
  1. Ring Video Doorbell 3 Camera Replacement, Faceplate: step 1, image 1 of 2 Ring Video Doorbell 3 Camera Replacement, Faceplate: step 1, image 2 of 2
    • Look at the bottom of the device and locate the arrow.
    • Use your fingers to push the silver faceplate in the direction of the arrow.
  2. Ring Video Doorbell 3 Camera Replacement: step 2, image 1 of 1
    • Push up to take the face plate off.
  3. Ring Video Doorbell 3 Camera Replacement, Battery: step 3, image 1 of 2 Ring Video Doorbell 3 Camera Replacement, Battery: step 3, image 2 of 2
    • Push in the silver tab and slide the battery out.
  4. Ring Video Doorbell 3 Camera Replacement, Motherboard: step 4, image 1 of 3 Ring Video Doorbell 3 Camera Replacement, Motherboard: step 4, image 2 of 3 Ring Video Doorbell 3 Camera Replacement, Motherboard: step 4, image 3 of 3
    • Remove the 6 screws with a Torx T6 screwdriver.
    • Remove the 2 screws with a Torx T5 screwdriver.
  5. Ring Video Doorbell 3 Camera Replacement: step 5, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 5, image 2 of 2
    • Put your thumb where the battery was and push outwards to remove the back case.
  6. Ring Video Doorbell 3 Camera Replacement: step 6, image 1 of 3 Ring Video Doorbell 3 Camera Replacement: step 6, image 2 of 3 Ring Video Doorbell 3 Camera Replacement: step 6, image 3 of 3
    • Get a tweezer, and remove the black and grey antenna wires.
  7. Ring Video Doorbell 3 Camera Replacement: step 7, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 7, image 2 of 2
    • Disconnect the camera sensor.
  8. Ring Video Doorbell 3 Camera Replacement: step 8, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Be cautious to not rip the ribbon cable.
    • Lift the black tab above the ribbon to unlock it.
    • Use the tweezers to pull out the ribbon.
  9. Ring Video Doorbell 3 Camera Replacement: step 9, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 9, image 2 of 2
    • Use a Torx T6 but to take out the four screws on the first motherboard.
  10. Ring Video Doorbell 3 Camera Replacement: step 10, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 10, image 2 of 2
    • Use an opening tool to take out the motherboard.
    • Make sure to push in the 5 pins while taking out the motherboards to ensure that they do not break.
  11. Ring Video Doorbell 3 Camera Replacement: step 11, image 1 of 1
    • The motherboard has been taken out, and now it is free to be replaced or worked on.
  12. Ring Video Doorbell 3 Camera Replacement: step 12, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 12, image 2 of 2
    • Flip the two boards on the side.
    • Gently pull the motherboard and the camera board apart.
  13. Ring Video Doorbell 3 Camera Replacement: step 13, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 13, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the two screws.
  14. Ring Video Doorbell 3 Camera Replacement: step 14, image 1 of 2 Ring Video Doorbell 3 Camera Replacement: step 14, image 2 of 2
    • Carefully remove the camera lens from the board.
    • Replace Motherboard(s) if needed.
    • Replace Camera if needed.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 47
All Time: 471
