Ring Outdoor Security Cam Camera Replacement
    1. Ring Outdoor Security Cam Camera Replacement, Camera: step 1, image 1 of 1
      • Remove the six 6 mm Phillips #00 screws from the back on the device.
      Ask FixBot
    2. Ring Outdoor Security Cam Camera Replacement: step 2, image 1 of 1
      • Pry off the aluminum plate using a plastic opening tool.
      Ask FixBot
    3. Ring Outdoor Security Cam Camera Replacement: step 3, image 1 of 1
      • Use an opening tool to pry the back plate off of the device.
      Ask FixBot
    4. Ring Outdoor Security Cam Camera Replacement: step 4, image 1 of 1
      • Disconnect the battery power leads using a plastic opening tool.
      Ask FixBot
    5. Ring Outdoor Security Cam Camera Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Ask FixBot
    6. Ring Outdoor Security Cam Camera Replacement: step 6, image 1 of 1
      • Disconnect the ribbon cable carefully at the bottom of the device.
      • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
      Ask FixBot
    7. Ring Outdoor Security Cam Camera Replacement: step 7, image 1 of 1
      • Pull the top of the motherboard up and out of the device.
      Ask FixBot
    8. Ring Outdoor Security Cam Camera Replacement: step 8, image 1 of 2 Ring Outdoor Security Cam Camera Replacement: step 8, image 2 of 2
      • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
      • Then remove the three plastic spacers on the device.
      Ask FixBot
    9. Ring Outdoor Security Cam Camera Replacement: step 9, image 1 of 3 Ring Outdoor Security Cam Camera Replacement: step 9, image 2 of 3 Ring Outdoor Security Cam Camera Replacement: step 9, image 3 of 3
      • Pry the motherboard out with a plastic opening tool.
      • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 83
All Time: 1,303
