Up to 20% off select tools
Ring Floodlight Cam Camera Module Replacement
View statistics:
Past 24 Hours:
10
Past 7 Days:
26
Past 30 Days:
138
All Time:
602
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 hours
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the camera module for the Ring Floodlight Cam. The camera module plays a critical part in the Ring Floodlight Cam, providing high-definition 4k or 1080p surveillance video footage, recording based on motion activation, and audio in real time.
Disclaimer - This guide involves the drilling of the device shell, which can lead to exposure of various weathering implications if said drill holes are not repaired before use again. As a recommendation, outside resources/products such as weathering tape (ex: Gorilla All Weather Tape) or waterproof sealant putty (ex: Flex Paste) can be used to seal the damage.
Warning - If attempting to remove screws without drilling use a low profile wrench instead of a screwdriver and unless other attempts to remove screws non-destructively have failed follow the guide as originally instructed.
    1. Ring Floodlight Cam Camera Module Replacement, Motherboard: step 1, image 1 of 2 Ring Floodlight Cam Camera Module Replacement, Motherboard: step 1, image 2 of 2
      • Remove the external cover with a Jimmy tool.
      Ask FixBot
    2. Ring Floodlight Cam Camera Module Replacement: step 2, image 1 of 2 Ring Floodlight Cam Camera Module Replacement: step 2, image 2 of 2
      • Remove the four outer cover 4.5mm screws with a Philips 1 screwdriver.
      Ask FixBot
    3. Ring Floodlight Cam Camera Module Replacement: step 3, image 1 of 1
      • Remove the internal cover.
      Ask FixBot
    4. Ring Floodlight Cam Camera Module Replacement: step 4, image 1 of 1
      • Disconnect the flexible flat cable (FFC) from the motherboard.
      Ask FixBot
    5. Ring Floodlight Cam Camera Module Replacement: step 5, image 1 of 1
      • Remove the three-prong connector with angled tweezers.
      Ask FixBot
    6. Ring Floodlight Cam Camera Module Replacement: step 6, image 1 of 1
      • Remove the 2mm screws with a Phillips #00 screwdriver.
      Ask FixBot
    7. Ring Floodlight Cam Camera Module Replacement: step 7, image 1 of 2 Ring Floodlight Cam Camera Module Replacement: step 7, image 2 of 2
      • Remove the power supply.
      • Disconnect the power supply from the device.
      Ask FixBot
    8. Ring Floodlight Cam Camera Module Replacement: step 8, image 1 of 1
      • Remove the 2mm screws with a Phillips 00 screwdriver from the base connector.
      • From this step forward use a low profile wrench instead of a screwdriver with the correct bit size to remove screws non-destructively.
      Ask FixBot
    9. Ring Floodlight Cam Camera Module Replacement: step 9, image 1 of 2 Ring Floodlight Cam Camera Module Replacement: step 9, image 2 of 2
      • Drill holes into the exterior with a 1/16 drill bit.
      • Skip this step unless you lack the specialized tools or other attempts to remove screws non destructively were unsuccessful.
      Ask FixBot
    10. Ring Floodlight Cam Camera Module Replacement: step 10, image 1 of 1
      • Unscrew the 2mm screws on the metal baseplate with a Phillips 00 screwdriver.
      Ask FixBot
    11. Ring Floodlight Cam Camera Module Replacement: step 11, image 1 of 1
      • Remove the metal baseplate.
      Ask FixBot
    12. Ring Floodlight Cam Camera Module Replacement: step 12, image 1 of 1
      • Remove the power connector from the motherboard using angled tweezers.
      Ask FixBot
    13. Ring Floodlight Cam Camera Module Replacement: step 13, image 1 of 1
      • Remove the front-end flexible flat cable (FFC) with angled tweezers.
      Ask FixBot
    14. Ring Floodlight Cam Camera Module Replacement: step 14, image 1 of 1
      • Remove the motion sensor flat flexible cable (FFC).
      Ask FixBot
    15. Ring Floodlight Cam Camera Module Replacement: step 15, image 1 of 2 Ring Floodlight Cam Camera Module Replacement: step 15, image 2 of 2
      • Remove the motherboard module.
      Ask FixBot
    1. Ring Floodlight Cam Camera Module Replacement, Camera Module: step 16, image 1 of 1
      • Drill holes with a 1/16 drill bit.
      Ask FixBot
    2. Ring Floodlight Cam Camera Module Replacement: step 17, image 1 of 2 Ring Floodlight Cam Camera Module Replacement: step 17, image 2 of 2
      • Remove the 2mm screws with an iFixit PH00 screwdriver.
      Ask FixBot
    3. Ring Floodlight Cam Camera Module Replacement: step 18, image 1 of 1
      • Peel the copper strip from camera module.
      Ask FixBot
    4. Ring Floodlight Cam Camera Module Replacement: step 19, image 1 of 2 Ring Floodlight Cam Camera Module Replacement: step 19, image 2 of 2
      • Unplug the WiFi antenna cables with angled tweezers.
      Ask FixBot
    5. Ring Floodlight Cam Camera Module Replacement: step 20, image 1 of 2 Ring Floodlight Cam Camera Module Replacement: step 20, image 2 of 2
      • Remove 2mm screws with a PH00 screwdriver.
      Ask FixBot
    6. Ring Floodlight Cam Camera Module Replacement: step 21, image 1 of 1
      • Remove the 3 pin power connector from the camera module.
      Ask FixBot
    7. Ring Floodlight Cam Camera Module Replacement: step 22, image 1 of 3 Ring Floodlight Cam Camera Module Replacement: step 22, image 2 of 3 Ring Floodlight Cam Camera Module Replacement: step 22, image 3 of 3
      • Remove the camera module.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order and before inserting power supply fill the drill holes with plastic putty.
Author
with
Samuel Garcia
381 Reputation
2 Guides authored
Texas Tech, Team 41-3, Johansen Spring 2026 Member of Texas Tech, Team 41-3, Johansen Spring 2026
TTU-JOHANSEN-S26S41G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 26
Past 30 Days: 138
All Time: 602
