Shop the Holiday Gift Guide
Right Temple
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
15
All Time:
150
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Right Temple
Tools
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
    1. Right Temple, Remove the screw covers: step 1, image 1 of 2 Right Temple, Remove the screw covers: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the six screw covers from the right temple.
      Ask FixBot
    2. Right Temple, Unfasten the right temple: step 2, image 1 of 2 Right Temple, Unfasten the right temple: step 2, image 2 of 2
      • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
      • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
      Ask FixBot
    3. Right Temple, Remove the outer hinge cover: step 3, image 1 of 3 Right Temple, Remove the outer hinge cover: step 3, image 2 of 3 Right Temple, Remove the outer hinge cover: step 3, image 3 of 3
      • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
      • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
      • Remove the outer hinge cover.
      Ask FixBot
    4. Right Temple, Remove the outer temple: step 4, image 1 of 3 Right Temple, Remove the outer temple: step 4, image 2 of 3 Right Temple, Remove the outer temple: step 4, image 3 of 3
      • Insert the flat end of a spudger in the gap between the outer and inner temple.
      • Slide the spudger along the gap to separate the clips securing the outer temple.
      Ask FixBot
    5. Right Temple: step 5, image 1 of 3 Right Temple: step 5, image 2 of 3 Right Temple: step 5, image 3 of 3
      • Slide the top of the outer temple out of its slot in the hinge.
      Ask FixBot
    6. Right Temple: step 6, image 1 of 2 Right Temple: step 6, image 2 of 2
      Tesa 61395 Tape
      $10.95
      Buy
      • The speaker is lightly adhered to the outer temple.
      • Rotate the outer temple towards you to access the speaker.
      • Slide the flat end of a spudger under the speaker to separate its adhesive.
      • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
      Ask FixBot
    7. Right Temple: step 7, image 1 of 3 Right Temple: step 7, image 2 of 3 Right Temple: step 7, image 3 of 3
      • Thread the outer temple off of the USB‑C cable and remove it.
      Ask FixBot
    8. Right Temple: step 8, image 1 of 2 Right Temple: step 8, image 2 of 2
      • Pull the inner temple out of its slot in the hinge and remove it.
      Ask FixBot
    9. Right Temple, Peel the hinge tape: step 9, image 1 of 2 Right Temple, Peel the hinge tape: step 9, image 2 of 2
      • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
      Ask FixBot
    10. Right Temple, Unfasten the inner hinge cover: step 10, image 1 of 1
      • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
      • One 3.1 mm‑long screw
      • One 4.9 mm‑long screw
      Ask FixBot
    11. Right Temple, Remove the inner hinge cover: step 11, image 1 of 3 Right Temple, Remove the inner hinge cover: step 11, image 2 of 3 Right Temple, Remove the inner hinge cover: step 11, image 3 of 3
      • Rotate the inner hinge cover off its groove in the frame.
      • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 150
