Right Speaker Driver Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Right Speaker Driver Removal, Remove the right earpad: step 1, image 1 of 2 Right Speaker Driver Removal, Remove the right earpad: step 1, image 2 of 2
      • The earpads are secured with magnets
      • Lift the right earpad (labeled R) straight up and remove it.
      Ask FixBot
    1. Right Speaker Driver Removal, Remove the right ear cup: step 2, image 1 of 3 Right Speaker Driver Removal, Remove the right ear cup: step 2, image 2 of 3 Right Speaker Driver Removal, Remove the right ear cup: step 2, image 3 of 3
      • Removing the ear cup isn’t required, but can make the repair easier. You can leave the cup attached and remove it later if needed.
      • Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled R).
      • Push down with your tool and pull the headband connector straight out of its socket.
      • The headband connector should slide out easily. If you're having trouble, reposition the tool and try again—you may need to angle the bit slightly.
      Ask FixBot
    1. Right Speaker Driver Removal, Set the right ear cup down: step 3, image 1 of 1
      • Set the right ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
      Ask FixBot
    2. Right Speaker Driver Removal, Turn the housing screws to the open position: step 4, image 1 of 2 Right Speaker Driver Removal, Turn the housing screws to the open position: step 4, image 2 of 2
      • Turn these screws slowly and gently, stopping when you feel resistance—about 1/4 turn. If turned too far, the locking mechanism will break.
      • Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
      • Turn the top left and bottom right screws counterclockwise.
      • Turn the top right and bottom left screws clockwise.
      Ask FixBot
    3. Right Speaker Driver Removal, Soften the speaker housing adhesive: step 5, image 1 of 3 Right Speaker Driver Removal, Soften the speaker housing adhesive: step 5, image 2 of 3 Right Speaker Driver Removal, Soften the speaker housing adhesive: step 5, image 3 of 3
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • The perimeter of the speaker housing is secured to the cup with adhesive. This step shows a few methods to soften the adhesive so you can pry up the housing. If one isn't working, try a different method.
      • Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
      • Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
      • Don't heat the center of the speaker housing, or you'll damage the fragile mesh under the speaker cutouts and possibly the speaker.
      • For a detailed look at best practices for using a hair dryer, check out this guide.
      Ask FixBot
    4. Right Speaker Driver Removal, Pry up the speaker housing: step 6, image 1 of 3 Right Speaker Driver Removal, Pry up the speaker housing: step 6, image 2 of 3 Right Speaker Driver Removal, Pry up the speaker housing: step 6, image 3 of 3
      iSesamo Opening Tool
      $10.99
      Buy
      • The gap between the speaker housing and ear cup is extremely small. You'll need a thin tool such as a metal opening pick, iSesamo, or iFlex to pry up the housing.
      • Don't grip the iFlex or similar metal tools by the edges—they're sharp and may cut you. Consider wearing gloves to protect yourself.
      • Insert the flat side of your opening tool into the gap between the left side of the speaker housing and the lip of the ear cup (opposite the R marking).
      • Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
      • If the housing isn't coming up, repeat the previous step and try again. Don't try and force the housing out or you may damage it.
      Ask FixBot
    5. Right Speaker Driver Removal: step 7, image 1 of 3 Right Speaker Driver Removal: step 7, image 2 of 3 Right Speaker Driver Removal: step 7, image 3 of 3
      • Don't try to fully remove the speaker housing yet—a delicate ribbon cable still connects it to the ear cup.
      • Lift the speaker housing out of the ear cup to fully separate the remaining adhesive.
      • Flip the housing over the side of the cup and prop it up so you can access the cable.
      Ask FixBot
    6. Right Speaker Driver Removal, Remove the speaker housing cable cover: step 8, image 1 of 2 Right Speaker Driver Removal, Remove the speaker housing cable cover: step 8, image 2 of 2
      FixMat
      $36.95
      Buy
      • Don’t let any screws snap onto the speaker driver diaphragm or they'll damage it. The screws will be drawn towards the center by the speaker's magnet.
      • Use a Torx Plus 1IP screwdriver to remove the 1.7 mm‑long screw securing the speaker housing cable cover.
      Ask FixBot
    7. Right Speaker Driver Removal: step 9, image 1 of 2 Right Speaker Driver Removal: step 9, image 2 of 2
      • Use tweezers to remove the cover.
      Ask FixBot
    8. Right Speaker Driver Removal, Disconnect the speaker housing: step 10, image 1 of 2 Right Speaker Driver Removal, Disconnect the speaker housing: step 10, image 2 of 2
      • Use a spudger to pry up and disconnect the speaker housing press connector.
      Ask FixBot
    9. Right Speaker Driver Removal, Remove the speaker housing: step 11, image 1 of 1
      • Remove the speaker housing.
      Ask FixBot
    1. Right Speaker Driver Removal, Remove the speaker driver screws: step 12, image 1 of 3 Right Speaker Driver Removal, Remove the speaker driver screws: step 12, image 2 of 3 Right Speaker Driver Removal, Remove the speaker driver screws: step 12, image 3 of 3
      • Grip the screws with tweezers while loosening and removing them. Don’t let the screws snap onto the diaphragm.
      • Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
      • Two 6.0 mm‑long screws
      • One 6.0 mm‑long screw that's slightly thicker than the other two
      • Remove the 5.1 mm‑long standoff screw using one of the two methods below:
      • Apply constant downward force to avoid damaging the screw.
      • Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
      • Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
      Ask FixBot
    2. Right Speaker Driver Removal, Remove the speaker driver: step 13, image 1 of 3 Right Speaker Driver Removal, Remove the speaker driver: step 13, image 2 of 3 Right Speaker Driver Removal, Remove the speaker driver: step 13, image 3 of 3
      • Lift the top edge of the speaker and remove it, being careful not to touch the diaphragm.
      • If you're having trouble, use the point of a spudger to start lifting the speaker.
      • Set the speaker aside in a place where it won't attract small metal objects.
      Ask FixBot
Finish Line
Spencer Day
205,788 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 104
