Shop the Holiday Gift Guide
Right Microphone Installation
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
14
All Time:
72
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Parts
Tools
  • Angled Tweezers
    $3.99 $4.99
    4.9
  • Spudger
    4.9
    1. Right Microphone Installation, Replace the old microphone adhesive: step 1, image 1 of 2 Right Microphone Installation, Replace the old microphone adhesive: step 1, image 2 of 2
      • Only follow this step if your replacement microphone has adhesive pre-installed, or if you can't reuse the old adhesive.
      • Use tweezers to remove all the old microphone adhesive.
      • If you're replacing the adhesive, cut a thin piece the length of the distance between the two alignment pegs and apply it where the old adhesive was.
      Ask FixBot
    2. Right Microphone Installation, Place the microphone: step 2, image 1 of 3 Right Microphone Installation, Place the microphone: step 2, image 2 of 3 Right Microphone Installation, Place the microphone: step 2, image 3 of 3
      • It may be easier to place the microphone with the ear cup standing up at an angle.
      • If your microphone has pre-installed adhesive, remove the liner.
      • Use tweezers to gently grip the microphone and put it into place.
      • Make sure the alignment pegs go through their cutouts and the cable is on the right side.
      • With the microphone properly aligned, use the flat end of a spudger to push the microphone into place.
      Ask FixBot
    3. Right Microphone Installation, Fold the microphone cable: step 3, image 1 of 2 Right Microphone Installation, Fold the microphone cable: step 3, image 2 of 2
      • Use tweezers to gently push the cable inwards towards the microphone.
      • Don't fold or crease the cable—use the pre-folded sections to guide it into place.
      Ask FixBot
Finish Line
Spencer Day
210,419 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 72
