Right Joy-Con Joystick Replacement
  1. Right Joy-Con Joystick Replacement, Right Joystick: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Remove the four tri-point Y00 screws from the back panel of the Joy-Con.
    • These screws are each 6.2 mm long, but it's still a good idea to keep them organized and make sure they go back in their proper holes!
  2. Right Joy-Con Joystick Replacement, Opening the case: step 2, image 1 of 3 Right Joy-Con Joystick Replacement, Opening the case: step 2, image 2 of 3 Right Joy-Con Joystick Replacement, Opening the case: step 2, image 3 of 3
    • Insert an opening pick under the lower side of the back panel (opposite the R and ZR buttons).
    • Slide the flat edge of an opening pick up the side of the Joy-Con.
    • Be careful not to slide the opening pick too far inside the Joy-Con. This may damage the inner components. The back panel has shallow interference-fit tabs on the side opposite the charging rail. These loosen fairly easily, so not much pressure is needed.
  3. Right Joy-Con Joystick Replacement, Opening the case: step 3, image 1 of 2 Right Joy-Con Joystick Replacement, Opening the case: step 3, image 2 of 2
    • Open the Joy-Con like a book, with the charging rail facing away from you.
    • Don’t try to fully remove the back panel yet. There are still two cables connecting the charging rail to the motherboard.
  4. Right Joy-Con Joystick Replacement, Disconnecting the battery: step 4, image 1 of 2 Right Joy-Con Joystick Replacement, Disconnecting the battery: step 4, image 2 of 2
    • Use a spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
    • Be extremely careful while you pry up the battery connector. If it does not come up easily, try gently pulling on the wires to disconnect it.
  5. Right Joy-Con Joystick Replacement, Removing the battery: step 5, image 1 of 3 Right Joy-Con Joystick Replacement, Removing the battery: step 5, image 2 of 3 Right Joy-Con Joystick Replacement, Removing the battery: step 5, image 3 of 3
    • The following two steps show the removal of the battery and the coaxial antenna cable from the midframe. These two steps make for a less cluttered repair, but are not essential. If you want, you can leave the battery and the grey coax cable in place here and proceed to step 7.
    • Insert an opening pick between the battery and the Joy-Con housing. Gently pry out the battery, which is lightly taped in place.
    • Be careful not to deform or puncture the battery—it can catch fire or explode if damaged.
  6. Right Joy-Con Joystick Replacement, Removing the antenna: step 6, image 1 of 2 Right Joy-Con Joystick Replacement, Removing the antenna: step 6, image 2 of 2
    • Before you perform this step, take note of how the antenna cable and its PCB are seated for proper reassembly later.
    • Carefully de-thread the upper half of the grey antenna cable out of the battery cavity.
  7. Right Joy-Con Joystick Replacement, Disconnect the antenna: step 7, image 1 of 2 Right Joy-Con Joystick Replacement, Disconnect the antenna: step 7, image 2 of 2
    • Pry up with the pointy end of a spudger to disconnect the antenna cable's coaxial connector from the motherboard.
    • Remove the grey antenna cable.
    • During reassembly, reconnect the antenna cable, then make sure it is routed through the battery cavity in the midframe as it was before you took it out.
  8. Right Joy-Con Joystick Replacement, Removing the Midframe: step 8, image 1 of 1
    • Remove the three 3.5 mm Phillips #00 screws on midframe.
    • Do not attempt to remove the midframe yet. There is a fragile cable that still connects the ZR button on the midframe to the motherboard underneath.
  9. Right Joy-Con Joystick Replacement, Removing the midframe: step 9, image 1 of 2 Right Joy-Con Joystick Replacement, Removing the midframe: step 9, image 2 of 2
    • Carefully flip the midframe over and away from the motherboard.
    • Do your best not to stress the short ribbon cable attached to the ZR button during this step.
  10. Right Joy-Con Joystick Replacement, Disconnecting the midframe: step 10, image 1 of 3 Right Joy-Con Joystick Replacement, Disconnecting the midframe: step 10, image 2 of 3 Right Joy-Con Joystick Replacement, Disconnecting the midframe: step 10, image 3 of 3
    • The ZR button cable is locked in place by a small ZIF connector on the motherboard. Use tweezers or a spudger to flip up the ZIF connector lock.
    • Use tweezers to gently pull the ZR button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
    • ++The ZR button cable in this Joy-Con is short and can be tricky to reconnect. If you are worried about not being able to reconnect it, you can skip this step and leave it connected, which we recommend.++'
    • If you choose to leave the cable connected, be careful. Work slowly and do your best to keep the midframe from moving around as you perform the last few steps to avoid damaging the cable.
  11. Right Joy-Con Joystick Replacement, Disconnecting the joystick: step 11, image 1 of 3 Right Joy-Con Joystick Replacement, Disconnecting the joystick: step 11, image 2 of 3 Right Joy-Con Joystick Replacement, Disconnecting the joystick: step 11, image 3 of 3
    • The joystick cable is also locked into place by a ZIF connector. Use tweezers or a spudger to flip the ZIF lock upward and carefully disconnect the cable.
  12. Right Joy-Con Joystick Replacement: step 12, image 1 of 1
    • Remove the two 3.5 mm Phillips #00 screws from the joystick.
  13. Right Joy-Con Joystick Replacement, Removing the joystick: step 13, image 1 of 3 Right Joy-Con Joystick Replacement, Removing the joystick: step 13, image 2 of 3 Right Joy-Con Joystick Replacement, Removing the joystick: step 13, image 3 of 3
    • Carefully remove the joystick from its housing.
    • There is a thin black gasket around the hole where the joystick pokes through the Joy-Con. Do your best not to disturb this gasket as you remove the joystick!
    • Once the Joy-Con is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick. Additionally, you may need to power cycle your Switch by holding down the power button for 10-15 seconds until it turns off, then turning it back on.
Kyler Saunders
4,335 Reputation
1 Guide authored
The.idoc.repair Member of The.idoc.repair
Business
1 Member
9 Guides authored
Past 24 Hours: 184
Past 7 Days: 1,147
Past 30 Days: 4,525
All Time: 324,035
