Shop the Holiday Gift Guide
Right Joy-Con 2 Midframe Removal
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
18
All Time:
153
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Right Joy-Con 2 Midframe Removal, Disconnect the battery: step 1, image 1 of 2 Right Joy-Con 2 Midframe Removal, Disconnect the battery: step 1, image 2 of 2
      • Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
      • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
      Ask FixBot
    2. Right Joy-Con 2 Midframe Removal, Remove the release button: step 2, image 1 of 2 Right Joy-Con 2 Midframe Removal, Remove the release button: step 2, image 2 of 2
      • Pick up the release button and remove it.
      Ask FixBot
    3. Right Joy-Con 2 Midframe Removal, Remove the trigger: step 3, image 1 of 2 Right Joy-Con 2 Midframe Removal, Remove the trigger: step 3, image 2 of 2
      • If your JIS 00 driver is able to access the screw underneath the trigger button, you may skip this step.
      • Insert an opening pick between the bumper (R) and trigger (ZR) buttons at the top of the controller.
      • Use the opening pick to pry the trigger away from the bumper until it pops off the controller.
      • You can lightly hold the ZR button with your finger to avoid launching it.
      Ask FixBot
    4. Right Joy-Con 2 Midframe Removal, Remove the screws: step 4, image 1 of 2 Right Joy-Con 2 Midframe Removal, Remove the screws: step 4, image 2 of 2
      • Use a JIS 00 driver to remove the five screws securing the midframe:
      • Four 3.9 mm‑long silver screws
      • One 6.2 mm‑long black screw
      Ask FixBot
    5. Right Joy-Con 2 Midframe Removal, Remove the bumper: step 5, image 1 of 2 Right Joy-Con 2 Midframe Removal, Remove the bumper: step 5, image 2 of 2
      • Hold the midframe lightly in place.
      • Pull the bumper (R) button off its mounting pegs and remove it.
      • The midframe will lift slightly when removing this button.
      Ask FixBot
    6. Right Joy-Con 2 Midframe Removal, Remove the bracket: step 6, image 1 of 2 Right Joy-Con 2 Midframe Removal, Remove the bracket: step 6, image 2 of 2
      • Pick up the release button mounting bracket and remove it.
      Ask FixBot
    7. Right Joy-Con 2 Midframe Removal, Prop up the controller: step 7, image 1 of 3 Right Joy-Con 2 Midframe Removal, Prop up the controller: step 7, image 2 of 3 Right Joy-Con 2 Midframe Removal, Prop up the controller: step 7, image 3 of 3
      • Use the back cover to prop up the controller while you work.
      • The buttons on the front of the controller should rest on the back cover's lip to keep it stable.
      Ask FixBot
    8. Right Joy-Con 2 Midframe Removal, Lift the trigger button board: step 8, image 1 of 1
      • Use a JIS 00 driver to remove the 3.9 mm‑long silver screw securing the trigger button board.
      Ask FixBot
    9. Right Joy-Con 2 Midframe Removal: step 9, image 1 of 2 Right Joy-Con 2 Midframe Removal: step 9, image 2 of 2
      • Insert the point of a spudger underneath the board, and lift it until it pops up.
      Ask FixBot
    10. Right Joy-Con 2 Midframe Removal, Remove the midframe: step 10, image 1 of 2 Right Joy-Con 2 Midframe Removal, Remove the midframe: step 10, image 2 of 2
      • Pick up and remove the midframe.
      Ask FixBot
    11. Right Joy-Con 2 Midframe Removal, Disconnect the trigger board: step 11, image 1 of 2 Right Joy-Con 2 Midframe Removal, Disconnect the trigger board: step 11, image 2 of 2
      • Use the point of a spudger to flip up the locking flap on the trigger button ZIF connector, located on the controller's board.
      Ask FixBot
    12. Right Joy-Con 2 Midframe Removal: step 12, image 1 of 2 Right Joy-Con 2 Midframe Removal: step 12, image 2 of 2
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      • Remove the trigger button board.
      Ask FixBot
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 18
All Time: 153
