Shop the Holiday Gift Guide
Right Joy-Con 2 Midframe Installation
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
15
All Time:
160
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Right Joy-Con 2 Midframe Installation, Connect the trigger button board: step 1, image 1 of 3 Right Joy-Con 2 Midframe Installation, Connect the trigger button board: step 1, image 2 of 3 Right Joy-Con 2 Midframe Installation, Connect the trigger button board: step 1, image 3 of 3
      • Make sure the locking flap is flipped up on the trigger cable's ZIF connector.
      • Position the trigger button board so its ribbon cable is aligned with its ZIF connector on the board.
      • Use tweezers or your fingers to gently slide the ribbon cable into its ZIF connector.
      • Flip the locking flap down to secure the cable.
      Ask FixBot
    2. Right Joy-Con 2 Midframe Installation, Install the midframe: step 2, image 1 of 2 Right Joy-Con 2 Midframe Installation, Install the midframe: step 2, image 2 of 2
      • Align the midframe with its screw holes on the outer edge of the controller and set it into place.
      Ask FixBot
    3. Right Joy-Con 2 Midframe Installation, Install the trigger button board: step 3, image 1 of 3 Right Joy-Con 2 Midframe Installation, Install the trigger button board: step 3, image 2 of 3 Right Joy-Con 2 Midframe Installation, Install the trigger button board: step 3, image 3 of 3
      • Use tweezers or your fingers to set the bottom edge of the trigger button board underneath its tab on the midframe.
      • Press the board into place so the black peg on the midframe protrudes through the hole on the bottom corner of the board.
      Ask FixBot
    4. Right Joy-Con 2 Midframe Installation: step 4, image 1 of 1
      • Use a JIS 00 driver to install the 3.9 mm‑long silver screw securing the trigger button board.
      Ask FixBot
    5. Right Joy-Con 2 Midframe Installation, Install the bumper: step 5, image 1 of 2 Right Joy-Con 2 Midframe Installation, Install the bumper: step 5, image 2 of 2
      • Align the two springs on the bumper with their two posts on the midframe, and press it into place.
      • The bumper is held in place by the front shell of the controller. If it falls out, ensure it is fully seated in the shell.
      Ask FixBot
    6. Right Joy-Con 2 Midframe Installation, Install the midframe screws: step 6, image 1 of 2 Right Joy-Con 2 Midframe Installation, Install the midframe screws: step 6, image 2 of 2
      • Use a JIS 00 driver to install the three 3.9 mm‑long silver screws securing the midframe.
      Ask FixBot
    7. Right Joy-Con 2 Midframe Installation, Install the bracket: step 7, image 1 of 2 Right Joy-Con 2 Midframe Installation, Install the bracket: step 7, image 2 of 2
      • Align the release button mounting bracket with its screw holes and press it in the frame so it snaps into place.
      • The corner with the protruding square should be facing the battery.
      Ask FixBot
    8. Right Joy-Con 2 Midframe Installation: step 8, image 1 of 2 Right Joy-Con 2 Midframe Installation: step 8, image 2 of 2
      • Use a JIS 00 driver to install the two screws securing the release button bracket.
      • One 3.9 mm‑long silver screw
      • One 6.2 mm‑long black screw
      Ask FixBot
    9. Right Joy-Con 2 Midframe Installation, Install the buttons: step 9, image 1 of 3 Right Joy-Con 2 Midframe Installation, Install the buttons: step 9, image 2 of 3 Right Joy-Con 2 Midframe Installation, Install the buttons: step 9, image 3 of 3
      • If you left the trigger button in place, skip this step.
      • Align the trigger button with the top of the controller, with the "ZR" engraving facing out.
      • Set the trigger button onto its metal spring. Ensure the legs of the spring are seated properly in their channels on the midframe.
      • Press firmly on the trigger button to snap it into place.
      • Check that the metal spring didn't fall out of position. If it did, remove the trigger, place it back into position, and try again.
      Ask FixBot
    10. Right Joy-Con 2 Midframe Installation: step 10, image 1 of 3 Right Joy-Con 2 Midframe Installation: step 10, image 2 of 3 Right Joy-Con 2 Midframe Installation: step 10, image 3 of 3
      • Hold the release button so its smooth face is perpendicular to the controller.
      • Insert the release button into its bracket.
      • If the release pin doesn't stick out of the controller when the button is pressed, the button isn't installed correctly. Re-insert or flip the button and try again.
      Ask FixBot
    11. Right Joy-Con 2 Midframe Installation, Connect the battery: step 11, image 1 of 3 Right Joy-Con 2 Midframe Installation, Connect the battery: step 11, image 2 of 3 Right Joy-Con 2 Midframe Installation, Connect the battery: step 11, image 3 of 3
      • Align the battery connector with its socket on the board.
      • Press down on the connector until it's fully seated.
      Ask FixBot
Author
with
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 160
