Right Joy-Con 2 Board Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Right Joy-Con 2 Board Removal, Disconnect the board: step 1, image 1 of 3 Right Joy-Con 2 Board Removal, Disconnect the board: step 1, image 2 of 3 Right Joy-Con 2 Board Removal, Disconnect the board: step 1, image 3 of 3
      • Repeat this procedure to disconnect the remaining three ZIF connectors on the controller's board.
      Ask FixBot
    2. Right Joy-Con 2 Board Removal, Remove the board screws: step 2, image 1 of 2 Right Joy-Con 2 Board Removal, Remove the board screws: step 2, image 2 of 2
      • Use a JIS 00 driver to remove the five 3.1 mm‑long black screws securing the board to the controller.
      Ask FixBot
    3. Right Joy-Con 2 Board Removal, Lift the board: step 3, image 1 of 2 Right Joy-Con 2 Board Removal, Lift the board: step 3, image 2 of 2
      • Insert the point of a spudger between the board and the controller, near the battery connector socket.
      • Pry up on the board enough to grasp its edge with your fingertips.
      Ask FixBot
    4. Right Joy-Con 2 Board Removal, Remove the board: step 4, image 1 of 3 Right Joy-Con 2 Board Removal, Remove the board: step 4, image 2 of 3 Right Joy-Con 2 Board Removal, Remove the board: step 4, image 3 of 3
      • Lift the board by its outer edges to a roughly 45-degree angle, so it's no longer being blocked by the joystick assembly.
      • Make sure the black tape is fully lifted off the back of the joystick module. Work slowly to avoid tearing the tape.
      • Remove the board.
      Ask FixBot
Nick Schultz
65,497 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 93
