Shop the Holiday Gift Guide
Right Joy-Con 2 Board Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
11
All Time:
137
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Right Joy-Con 2 Board Installation, Install the board: step 1, image 1 of 3 Right Joy-Con 2 Board Installation, Install the board: step 1, image 2 of 3 Right Joy-Con 2 Board Installation, Install the board: step 1, image 3 of 3
      • Lower the board's flat side into the controller at an angle.
      • Use a spudger to bend the joystick's ribbon cable so it's perpendicular with the joystick.
      • Lower the board so the joystick's ribbon cable routes through the joystick cut-out in the board. Ensure the board is sitting underneath the locking tab on the frame.
      Ask FixBot
    2. Right Joy-Con 2 Board Installation: step 2, image 1 of 3 Right Joy-Con 2 Board Installation: step 2, image 2 of 3 Right Joy-Con 2 Board Installation: step 2, image 3 of 3
      • Push the board towards the controller's inner edge (the side with the shoulder buttons) to prevent it from colliding with the joystick module.
      • Lower the board into the frame.
      • Use your finger or the flat end of a spudger to press the black tape onto the back of the joystick module.
      Ask FixBot
    3. Right Joy-Con 2 Board Installation: step 3, image 1 of 2 Right Joy-Con 2 Board Installation: step 3, image 2 of 2
      • Use a JIS 00 driver to install the five 3.1 mm‑long black screws securing the board to the controller.
      Ask FixBot
    4. Right Joy-Con 2 Board Installation, Connect the cables: step 4, image 1 of 3 Right Joy-Con 2 Board Installation, Connect the cables: step 4, image 2 of 3 Right Joy-Con 2 Board Installation, Connect the cables: step 4, image 3 of 3
      • Make sure the locking flap is flipped up on the joystick cable ZIF connector.
      • Insert the joystick ribbon cable into its ZIF connector until it's fully seated.
      • The brown portion of the cable should end at the golden line on the board.
      • Use your finger or a spudger to flip the locking flap down to secure the cable.
      Ask FixBot
    5. Right Joy-Con 2 Board Installation: step 5, image 1 of 3 Right Joy-Con 2 Board Installation: step 5, image 2 of 3 Right Joy-Con 2 Board Installation: step 5, image 3 of 3
      • Make sure the locking flap is flipped up on the Joy-Con connector cable ZIF connector.
      • Insert the Joy-Con connector ribbon cable into its ZIF connector until it's fully seated.
      Ask FixBot
    6. Right Joy-Con 2 Board Installation: step 6, image 1 of 3 Right Joy-Con 2 Board Installation: step 6, image 2 of 3 Right Joy-Con 2 Board Installation: step 6, image 3 of 3
      • Repeat this procedure for the shoulder button ZIF connector. The cable is fully seated when its brown "wings" are in their slots on both sides of the connector.
      • This connector can be tricky—you may need to hold the flap open, or hold the cable in place when closing the flap.
      Ask FixBot
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 137
