Rienok S1 Mini Case Replacement
    1. Rienok S1 Mini Case Replacement, Grille: step 1, image 1 of 2 Rienok S1 Mini Case Replacement, Grille: step 1, image 2 of 2
      • Start with the buttons panel up and facing you.
      • Wedge in one iFixit opening pick, and apply outward pressure to pop out one side of the grille.
      • Using a second pick, slide from the first pick towards the opposite end until one whole side is popped out.
      Ask FixBot
    2. Rienok S1 Mini Case Replacement: step 2, image 1 of 1
      • While holding the other side open so it doesn't snap closed, wedge in one opening pick into one corner of the closed side.
      • Apply outward pressure until that side also pops out.
      • Using a second opening pick, slide from the first one until both sides have popped out.
      Ask FixBot
    3. Rienok S1 Mini Case Replacement: step 3, image 1 of 1
      • Pull outward on one end, while holding the other open.
      • Pull in the opposite direction on the top or bottom rings while slightly rotating the center until the whole grille is removed.
      Ask FixBot
    1. Rienok S1 Mini Case Replacement, Top and Bottom Rings: step 4, image 1 of 2 Rienok S1 Mini Case Replacement, Top and Bottom Rings: step 4, image 2 of 2
      • Wedge an iFixit opening pick into the space between the ring and the housing.
      • Insert a Jimmy into the gap created.
      • Apply an out-and-upward pressure with the Jimmy to disconnect the plastic clips surrounding the ring.
      • Work the Jimmy around the ring, disconnecting the clips along the way until they are all disconnected.
      • It may help to insert additional opening picks as you go to keep the previous clips from reconnecting.
      Ask FixBot
    2. Rienok S1 Mini Case Replacement: step 5, image 1 of 2 Rienok S1 Mini Case Replacement: step 5, image 2 of 2
      • After removing the first ring, turn the device to the other side.
      • Repeat the previous step to remove the second ring.
      Ask FixBot
    1. Rienok S1 Mini Case Replacement, Buttons Panel: step 6, image 1 of 2 Rienok S1 Mini Case Replacement, Buttons Panel: step 6, image 2 of 2
      • Remove the six 8 mm black screws using a Phillips #000 screwdriver.
      Ask FixBot
    2. Rienok S1 Mini Case Replacement: step 7, image 1 of 2 Rienok S1 Mini Case Replacement: step 7, image 2 of 2
      • With the screws removed, grasp the buttons panel and pull it off.
      Ask FixBot
    1. Rienok S1 Mini Case Replacement, Case: step 8, image 1 of 3 Rienok S1 Mini Case Replacement, Case: step 8, image 2 of 3 Rienok S1 Mini Case Replacement, Case: step 8, image 3 of 3
      • Hold the device with the speakers facing up.
      • Remove the six 10 mm silver screws connecting the two halves of the case with a Phillips #1 screwdriver.
      Ask FixBot
    2. Rienok S1 Mini Case Replacement: step 9, image 1 of 3 Rienok S1 Mini Case Replacement: step 9, image 2 of 3 Rienok S1 Mini Case Replacement: step 9, image 3 of 3
      • Insert a Jimmy into the seam between both halves.
      • Lightly twist the Jimmy until a small gap appears.
      • Work the Jimmy across the length creating and widening the gap as you go across.
      • With the gap across the whole length, grasp both halves and lightly pull apart.
      • DO NOT yank apart; the two halves are still connected by a few cords.
      Ask FixBot
    3. Rienok S1 Mini Case Replacement: step 10, image 1 of 2 Rienok S1 Mini Case Replacement: step 10, image 2 of 2
      • Remove the foam glue from the plugs.
      • Grip the plugs with your fingernails, and gently pull each plug until all three are disconnected.
      • If replacing the case, pull on the battery and motherboard, and they will come right out.
      Ask FixBot
Zoey S.
823 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 72
All Time: 717
