Introduction
This is a guide designed for replacing a broken direction switch in a RIDGID X4 18V Litium-Ion Impact Driver. This direction switch is imperative to the functionality of the driver. The direction switch determines whether the driver is going to rotate clockwise or counterclockwise.
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
Pull out all electrical components from housing by hand.
Lift out the motor.
Follow the wires.
Remove the broken direction switch.
Replace the broken direction switch with a functional switch.
