Ricoh Shotmaster 130Z Zooming Lens Replacement
  1. Ricoh Shotmaster 130Z Zooming Lens Replacement, Zooming Lens: step 1, image 1 of 1
    • Set the dials to "A" (Auto), and Off mode.
    • You will not be able to move these dials once the case has been opened.
  2. Ricoh Shotmaster 130Z Zooming Lens Replacement: step 2, image 1 of 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 2, image 2 of 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 2, image 3 of 3
    • Remove the 5 Phillips screws from the sides and the back.
  3. Ricoh Shotmaster 130Z Zooming Lens Replacement: step 3, image 1 of 2 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 3, image 2 of 2
    • Remove the 5mm JIS #00 screws from the bottom of the camera.
    • Pay attention to the 6mm screws on the sides of the tripod slot, as they are a slightly different size from the rest of the screws. However, you still may use a J00 screwdriver to remove them.
  4. Ricoh Shotmaster 130Z Zooming Lens Replacement: step 4, image 1 of 2 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 4, image 2 of 2
    • Using an opening tool, lift the case of the tripod slot (on the bottom) until the back portion of the case is released.
    • Continue to use the the opening tool to insert it and lift right next to the strap of the camera.
    • This will release the front portion of the case.
  5. Ricoh Shotmaster 130Z Zooming Lens Replacement: step 5, image 1 of 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 5, image 2 of 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 5, image 3 of 3
    • Use a JIS #0 screwdriver to remove the three marked screws found around the perimeter of the lens.
  6. Ricoh Shotmaster 130Z Zooming Lens Replacement: step 6, image 1 of 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 6, image 2 of 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: step 6, image 3 of 3
    • Proceed to remove the two screws using a JIS #00 screwdriver.
    • Use tweezers to lift the lens off of the board.
anna carolina von einem
450 Reputation
4 Guides authored
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 519
