Place curling iron on a flat surface along with the required tools and swivel cord replacement.
Using both hands, carefully detach both ends of the metal stand from the body by pulling away from the barrel.
Tool used on this step:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Unscrew the two 3mm screws from both sides of the barrel clip with a 3.0 flathead screwdriver to remove the clip from the barrel.
Set the two screws and barrel clip aside for reassembly at a later point.
Squeeze both sides of the barrel clip spring, and slide the component away from the barrel to remove.
Remove the 3mm screw holding the metal spring plate in place with the 3.0 flathead screwdriver.
Place the screw and spring plate to the side for reassembly at a later time.
Remove the two screws holding the plastic casing together using the 3.0 flathead screwdriver.
Remove the front plastic cover from the main body.
Place the two screws and plastic cover to the side for reassembly.
Remove the cylindrical barrel shell by sliding it away from the device's main heating element.
Carefully remove the plastic handle casing from the connected inside components, starting from the cylindrical heating element, to the black wire cord.
Carefully remove the swivel cord from the female socket.
Place the old swivel cord to the side, and insert the new swivel cord into the female socket gently.
