Revlon RVIR1008 Barrel Shell Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
67
All Time:
625
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Parts
Tools
    1. Revlon RVIR1008 Barrel Shell Replacement, Barrel Shell: step 1, image 1 of 1
      • Place curling iron on a flat surface along with required tools and barrel shell replacement.
      • Curling iron is extremely hot after use. Carefully unplug and let device sit and cool to room temperature before proceeding.
      Ask FixBot
    2. Revlon RVIR1008 Barrel Shell Replacement: step 2, image 1 of 1
      • Using both hands, carefully detach both ends of the metal stand from the body of the iron by pulling away from the barrel.
      Ask FixBot
    3. Revlon RVIR1008 Barrel Shell Replacement: step 3, image 1 of 2 Revlon RVIR1008 Barrel Shell Replacement: step 3, image 2 of 2
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Unscrew the 3mm screws from both sides of the barrel clip with a 3.0 flathead screwdriver to remove the clip from the barrel.
      • Set the two screws and barrel clip aside for reassembly.
      • Clip is prone to pop off from the body due to the weight of the spring. To prevent this, equally loosen each screw little by little.
      Ask FixBot
    4. Revlon RVIR1008 Barrel Shell Replacement: step 4, image 1 of 2 Revlon RVIR1008 Barrel Shell Replacement: step 4, image 2 of 2
      • Squeeze both sides of the barrel clip spring and slide the component away from the barrel to remove.
      • Slowly decompress the spring after removal from the spring plate to avoid any hazards.
      Ask FixBot
    5. Revlon RVIR1008 Barrel Shell Replacement: step 5, image 1 of 2 Revlon RVIR1008 Barrel Shell Replacement: step 5, image 2 of 2
      • Remove 3mm screw holding the metal spring plate in place with the 3.0 flathead screwdriver.
      • Place the screw and plate to the side for later reassembly.
      • Removing the screw allows for removal of the barrel from the iron itself. Be sure not to pull the barrel.
      Ask FixBot
    6. Revlon RVIR1008 Barrel Shell Replacement: step 6, image 1 of 3 Revlon RVIR1008 Barrel Shell Replacement: step 6, image 2 of 3 Revlon RVIR1008 Barrel Shell Replacement: step 6, image 3 of 3
      • Remove the two screws holding the plastic casing together using the 3.0 flathead screwdriver.
      • Remove the front plastic cover from the main body.
      • The plastic cover contains warnings and is located on the devices handle.
      • Once completed, the internal parts of the iron will be exposed.
      • Place the two screws and plastic cover to the side for later reassembly.
      Ask FixBot
    7. Revlon RVIR1008 Barrel Shell Replacement: step 7, image 1 of 1
      • Remove the cylindrical barrel shell by sliding it away from the devices main heating element. wisdom here.
      • Retrieve replacement barrel shell and slide it onto the devices main heating element.
      • Be careful to grip the device firmly and precisely to avoid stripping away the internal components underneath the handle.
      Ask FixBot
Cassidy Madrigal
113 Reputation
1 Guide authored
UW Tacoma, Team S3-G2, Liner Spring 2017 Member of UW Tacoma, Team S3-G2, Liner Spring 2017
UWT-LINER-S17S3G2
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 67
All Time: 625
