Revlon 473 Disassembly
  1. Revlon 473 Disassembly, Shell: step 1, image 1 of 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Disassembly: step 2, image 1 of 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Disassembly: step 3, image 1 of 3 Revlon 473 Disassembly: step 3, image 2 of 3 Revlon 473 Disassembly: step 3, image 3 of 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Disassembly, Revlon 473 Disassembly: step 4, image 1 of 1
    • Take the head of the hairdryer and pull the pieces apart.
  5. Revlon 473 Disassembly: step 5, image 1 of 1
    • Remove the black vent from the grey cylindrical piece.
  6. Revlon 473 Disassembly: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • If there is lint in the vent, use tweezers or a toothbrush to extract it from the vent.
    • This will keep the fan from getting clogged and malfunctioning.
  7. Revlon 473 Disassembly: step 7, image 1 of 2 Revlon 473 Disassembly: step 7, image 2 of 2
    • Clean the other black vent with a toothbrush.
  8. Revlon 473 Disassembly: step 8, image 1 of 1
    • Clean these two components with a paper towel.
Jessica Leyva
143 Reputation
5 Guides authored
Cal Poly, Team 1-5, Propen Fall 2012 Member of Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 1,971
