Introduction
Go to step 1 ↓Use this guide to replace the screen in a Retroid Pocket Flip handheld gaming console. The screen displays all visual output during gameplay and system navigation. If the screen is cracked, shows dead pixels, flickers, or no longer turns on, it may need to be replaced.
This repair is difficult and requires full disassembly of the device, including motherboard removal.
Before beginning, power off the device completely and remove the microSD card. Follow Electrostatic Discharge when working inside the device to prevent damage to sensitive electronic components.
The screen is fragile. Avoid bending, twisting, or applying pressure during removal to prevent damage.
Tools
Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
Use a plastic opening pick to carefully separate the back cover from the device.
Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
Use tweezers to disconnect the ribbon cables from the board.
Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
Use a plastic opening pick to carefully separate the screen from its back cover.
Use a plastic spudger to disconnect the first ribbon cable.
Use tweezers to disconnect the second ribbon cable.
