Retroid Pocket Flip Motherboard Replacement
    1. Retroid Pocket Flip Motherboard Replacement, Back Plate Assembly: step 1, image 1 of 2 Retroid Pocket Flip Motherboard Replacement, Back Plate Assembly: step 1, image 2 of 2
      • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
      • Use a plastic opening pick to carefully separate the back cover from the device.
      Ask FixBot
    2. Retroid Pocket Flip Motherboard Replacement: step 2, image 1 of 2 Retroid Pocket Flip Motherboard Replacement: step 2, image 2 of 2
      • Use a plastic spudger to carefully lift and disconnect the battery connector.
      • Use tweezers to disconnect the connector from its socket.
      Ask FixBot
    1. Retroid Pocket Flip Motherboard Replacement, Joystick: step 3, image 1 of 2 Retroid Pocket Flip Motherboard Replacement, Joystick: step 3, image 2 of 2
      • Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
      • Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
      • Use tweezers to remove the "R" sticker to reveal the last screw.
      Ask FixBot
    2. Retroid Pocket Flip Motherboard Replacement: step 4, image 1 of 3 Retroid Pocket Flip Motherboard Replacement: step 4, image 2 of 3 Retroid Pocket Flip Motherboard Replacement: step 4, image 3 of 3
      • Carefully lift and unstick the fan module using a plastic spudger, then remove it.
      • Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
      • Use a plastic spudger to carefully separate the shield from the board.
      • Do not pull abruptly: the shield is partially bonded to the CPU with thermal paste. You can use a hair dryer on low heat to soften the paste slightly before lifting the shield.
      Ask FixBot
    3. Retroid Pocket Flip Motherboard Replacement: step 5, image 1 of 3 Retroid Pocket Flip Motherboard Replacement: step 5, image 2 of 3 Retroid Pocket Flip Motherboard Replacement: step 5, image 3 of 3
      • Use tweezers to unclip and remove the two ribbon cables on each joystick module.
      • Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
      Ask FixBot
    1. Retroid Pocket Flip Motherboard Replacement, Motherboard: step 6, image 1 of 3 Retroid Pocket Flip Motherboard Replacement, Motherboard: step 6, image 2 of 3 Retroid Pocket Flip Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
      • Use tweezers to disconnect the ribbon cables from the board.
      • Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
      • Always lift the coaxial connector straight up. Do not pry at an angle, as this can detach the socket from the motherboard.
      Ask FixBot
    2. Retroid Pocket Flip Motherboard Replacement: step 7, image 1 of 2 Retroid Pocket Flip Motherboard Replacement: step 7, image 2 of 2
      • Remove the six 5.8 mm screws from the motherboard using a JIS #00 screwdriver.
      • Carefully lift the motherboard out of the device.
      Ask FixBot
Eya Sarah AHMED
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 92
All Time: 304
