This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide describes how to replace the spool, including the pull strap, on the SportPlus MR-010-2 rowing machine.
Remove the two Phillips screws from the plastic handle.
In order to remove the spool, you must first remove the rubber belt that connects the spool to the "cooling fan" from the spool.
There is high tension on the rubber belt. The tension is created by a nut on both sides of the spool that puts a screw under tension. These nuts must now be released alternately, little by little, until the rubber belt is loose and can be removed from the spool.
Follow the steps in reverse order to reassemble your device.
