Replacing flash memory to a cisco 837 series router
  1. Replacing flash memory to a cisco 837 series router, Flash memory: step 1, image 1 of 1
    • CISCO 837 Router
    • CISCO 877 Router
CONCLUSION
Replacing flash need a tftp server available;
Replacing flash need a copy of the IOS image;
Replacing flash need the usage of ROMMON; be sure that this is possible;
Removing the flash card and inserting it back is like replacing with a new one (IOS image will be gone, so don’t play it with ease);
use the first ethernet port to connect with the tftp server, although all 4 switch ports will work presumably because all being in the same first VLAN.
To reassemble your device, follow these instructions in reverse order and that's all.
Eneider Colina
2,370 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,479
