Replacing a TAE/DSL Socket with a RJ45 Jack
  1. Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: step 1, image 1 of 2 Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: step 1, image 2 of 2
    • Unscrew and remove the cover.
    • If you want to add an RJ45 jack but only have access to the first (non-replaceable) TAE outlet, you can mount the new RJ45 outlet next to it. Connect La on the new outlet to pin 6 of the old TAE outlet, and Lb to pin 5. You can use any type of shielded twisted pair cable for the connection.
    • Remove the the connections.
    • Keep track of La and Lb. You’ll need to know what wires to connect where in the new socket.
    • Unscrew the socket from the wall.
  2. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the new socket: step 2, image 1 of 1
    • Screw the new socket cover to the wall.
    • Refer to the manual that came with your outlet for this step.
  3. Replacing a TAE/DSL Socket with a RJ45 Jack, Punch down the wires: step 3, image 1 of 1
    • If you don’t know how to use a punch down tool, take a look at this guide first.
    • Connect La to pin 4 (Blue).
    • Connect Lb to pin 5 (White-Blue).
  4. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the socket: step 4, image 1 of 1
    • Mount the RJ45 socket inside the case and screw on the faceplate.
Have fun surfing the web!
Sebastian
31,160 Reputation
71 Guides authored
0 Guide Comments
Past 24 Hours: 60
Past 7 Days: 356
Past 30 Days: 1,448
All Time: 22,640
