Replacing a Baseball Bat Grip
  1. Replacing a Baseball Bat Grip, Baseball Bat Grip: step 1, image 1 of 3 Replacing a Baseball Bat Grip, Baseball Bat Grip: step 1, image 2 of 3 Replacing a Baseball Bat Grip, Baseball Bat Grip: step 1, image 3 of 3
    • Place the bat on a firm surface with the grip hanging off the edge.
    • Draw a line on the top of the old grip using a marker.
    • Practice caution when using the utility knife.
    • Use the utility knife to cut the tape where you made your mark.
    • Peel off the old grip.
    • Some bats may have an under layer of wrap that will require extra peeling to remove.
  2. Replacing a Baseball Bat Grip: step 2, image 1 of 2 Replacing a Baseball Bat Grip: step 2, image 2 of 2
    • Put on gloves and place the paper towels under the bat handle to catch the excess spilled residue cleaner.
    • Apply the residue cleaner to the handle.
    • Scrub off the residue with a rag.
  3. Replacing a Baseball Bat Grip: step 3, image 1 of 3 Replacing a Baseball Bat Grip: step 3, image 2 of 3 Replacing a Baseball Bat Grip: step 3, image 3 of 3
    • Sit in a chair and hold the bat in-between your legs with the knob facing upwards.
    • Take the pre-wrap, begin at the knob of the bat and wrap downward in a spiraling motion toward the mark.
    • When applying the pre-wrap, be sure to keep it evenly layered as it will quickly get thicker when doubled.
    • Stop applying the prewrap at the marked line.
  4. Replacing a Baseball Bat Grip: step 4, image 1 of 3 Replacing a Baseball Bat Grip: step 4, image 2 of 3 Replacing a Baseball Bat Grip: step 4, image 3 of 3
    • Hold the bat in the same position used for applying the pre-wrap.
    • Apply the electrical tape over the previous wrap using the same motion as before.
    • Be sure to evenly layer the tape to have a smooth wrap all the way down the handle.
  5. Replacing a Baseball Bat Grip: step 5, image 1 of 2 Replacing a Baseball Bat Grip: step 5, image 2 of 2
    • Apply a small piece of electrical tape at the beginning and end of the wrap to fasten it to the bat.
    • Now that your new grip is complete, you're ready to play ball!
Matthew McNabb
164 Reputation
1 Guide authored
Past 24 Hours: 13
Past 7 Days: 98
Past 30 Days: 555
All Time: 62,375
