Introduction
If the Sonos Play:1 has a damaged power/volume switchboard, this could prevent the device from powering on or off and could render the volume nonadjustable. To replace the switch board, remove the screws and protective plastic cover fastening the top cover to the speaker housing. Inside the cover lies the power/volume switch board.
Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
Once you pry open one end, use precision tweezers to remove rubber footing.
Remove the four 10 mm Torx security #10 screws that hold the base together.
Remove the base by lifting it vertically away from the bulk of the device.
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Using a plastic opening tool, pry open the top cap containing the power and volume button.
Vertically remove the top cap.
Using a screwdriver with a Torx T6 bit, remove the four highlighted 7mm screws.
Using you fingers remove the protective plastic plate covering the device.
Using your fingers remove the plastic cover plate securing the switchboard.
Using your fingers, remove the power/volume switch board.
From where can buy parts ??
4 other people completed this guide.
9 Comments
Where can I get the replacement power button?
Same quesion here from DK
where can i find board
Where can I find the Sonos Play 1 Power and Volume switch board.
Where can I buy a replacement switchboard?
Nun müsste man nur wissen wo man so eine Tasterplatine herbekommt,habe nähmlich den kleinenStecker beschädigt . ;-C
Same question i 2024
