Replacing Nokia X3-02 LCD
  1. Replacing Nokia X3-02 LCD, LCD: step 1, image 1 of 3 Replacing Nokia X3-02 LCD, LCD: step 1, image 2 of 3 Replacing Nokia X3-02 LCD, LCD: step 1, image 3 of 3
    • Before disassembling your phone, be sure it is powered off.
    • To remove the back cover press the two "buttons".
    • Remove the battery.
  2. Replacing Nokia X3-02 LCD: step 2, image 1 of 2 Replacing Nokia X3-02 LCD: step 2, image 2 of 2
    • Remove the three 3mm black screws on the top of the phone.
    • Remove the two 5mm screws.
    • Loosen these two screws at the bottom of the phone.
    • Probably these screws will not come out from their home, no matter. It is only important to unscrew them completely.
  3. Replacing Nokia X3-02 LCD: step 3, image 1 of 3 Replacing Nokia X3-02 LCD: step 3, image 2 of 3 Replacing Nokia X3-02 LCD: step 3, image 3 of 3
    • With a plastic opening tool remove the little piece of plastic in the bottom of of the phone.
    • The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them.
    • To remove the logic board assembly push from the rear of the phone.
  4. Replacing Nokia X3-02 LCD: step 4, image 1 of 2 Replacing Nokia X3-02 LCD: step 4, image 2 of 2
    • Remove the keyboard with a plastic opening tool.
13 other people completed this guide.
Matteo Moro
536 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 7
All Time: 4,787
