Introduction
This guide will walk you through removing and replacing the Nintendo DS battery.
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case, turning the screw counter-clockwise.
Remove the battery door.
Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
Insert the new Nintendo DS battery into the battery compartment with the positive and negative side against the metal prongs.
