Replacing Nintendo DS Battery
  1. Replacing Nintendo DS Battery, Battery: step 1, image 1 of 3 Replacing Nintendo DS Battery, Battery: step 1, image 2 of 3 Replacing Nintendo DS Battery, Battery: step 1, image 3 of 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case, turning the screw counter-clockwise.
    • Remove the battery door.
  2. Replacing Nintendo DS Battery: step 2, image 1 of 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
  3. Replacing Nintendo DS Battery: step 3, image 1 of 1
    • Remove the battery from the Nintendo DS.
dnguye26
694 Reputation
4 Guides authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
28 Guides authored
Past 24 Hours: 26
Past 7 Days: 101
Past 30 Days: 451
All Time: 22,502
